Old 05-25-2008, 01:19 PM
Steve Semeraro's Avatar
Steve Semeraro Steve Semeraro is offline
Blaupunkt Vintage Radio Basic Hook Up Questions
A recently purchased a Blaupunkt Frankford No. 7630 640 000 that has been refurbished, but did not come with wiring instructions. I have a few basic questions that I hope others can help me with.
There are two wires extending out of the back.
A thick grey wire with a large plug that I assume is for the antenna.
A thinner yellow wire. Is this the ground?
There is also a metal tab with a hole in it and a - sign on the top and a plus sign on the bottom. A sticker on the top indicates that this controls polarity and that when the - sign is facing up it reads "12 volt - battery" with a symbol consisting of a horizontal line and 3 vertical lines at the of lessening length. I assume this means negative ground when the - sign faces up?
Then there is a little speaker icon next to a hole with a plastic rim. I'm wondering how the speaker hooks up?
Thanks.
Steve Semeraro
1974 Alfa Romeo GTV
Old 05-27-2008, 07:50 AM
Il Vecchio's Avatar
Il Vecchio Il Vecchio is offline
Thanks.
If you want the "real deal" speaker plug, they can be ordered from Germany HERE (thanks, Jarrington!)
Lautsprecherstecker Blaupunkt • Ersatzteile • Blaupunkt
or, I have two spares single plug which work, which I can mail ya..
1966 Giulia Super (current)
1966 Giulia Super (R.I.P.)
1967 GTV (R.I.P.)
1955 1900CSS (R.I.P.)
Old 06-02-2008, 05:53 PM
Il Vecchio's Avatar
Steve, did you receive the speaker pluks? Did they work out for you?
1967 GTV (R.I.P.)
Old 06-02-2008, 06:01 PM
Yes. Thank you Peter. I just got them and the fit very nicely into the radio. I still haven't tried to install it into the car, but I will keep everyone posted on my progress and post a picture when it's done. Thanks again.
Steve Semeraro
1974 Alfa Romeo GTV
