Old 01-22-2005, 10:40 PM
Biscione's Avatar
--> Carb Spacers / $50 extra for you guys
http://www.alfabb.com/bb/forums/a/
Is $50 enough or should I charge more?
Old 01-23-2005, 02:12 PM
benjoys02's Avatar
spacers
i have a set of 45's and aluminum mounts on my car from e.b. spares. do these go between the aluminum mounts and the carbs? since it has a slot in the middle, do i need a set of rubber o-rings as well?
thanks!
benji
benji
Old 01-23-2005, 04:00 PM
Biscione's Avatar
Benji,
These (with the use of longer carb mount studs) go between the carbs and rubber mounts, or with some more work between the rubber mounts and the manifold - depending. You can use o-rings or copper silicone sealer for sealing; I have used both.
You will also need to add small aluminum spacers to extend the throttle linkage bracket and carb support rod to account for the extra distance of the carbs from the engine.
A little work is involved - or you could buy new cams for $500 to get a similar 9hp gain.
thanks!
benji
Old 01-23-2005, 09:59 PM
benjoys02's Avatar
carb spacers
hi,
thanks for the reply. i will inform my friend who is actually the one who's interested in them (not an alfa bb member yet) and get back to you as soon as he decides.
thanks again!
benji
benji
