Old 05-13-2007, 06:32 PM
oz3litre's Avatar
oz3litre oz3litre is offline
164Q cams
Does anyone know how to recognize the higher performance 164Q cams? Is there a part number on them or do they have easily recognizable features to distinguish them from standard 3.0 litre cams?
1988 75 3 litre, 1990 75 3 litre Potenziata, 1984 GTV 2000, 1992 Alfa 164 3 litre, 1990 Volvo 480 Turbo
Old 05-14-2007, 04:52 AM
quadrifoglio's Avatar
quadrifoglio quadrifoglio is offline
Q and LS 24v cams are the same.
Tim Annett
Cincinnati
'04 Jetta GLS 1.8t
'99 Laverda 750 Sport Carenata
Past Cars in order of appearance:
1965 Sunbeam Alpine IV
1983 Spider Veloce
1985 GTV-6
1987 Spider Quadrifoglio Verde
1986 Spider Veloce
1990 VW Corrado G60
1994 164 Quadrifoglio Verde
2000 BMW 323i
1995 164 Quadrifoglio Verde
Old 05-14-2007, 05:01 AM
oz3litre's Avatar
I'm talking about the difference between the Q cams and standard 3 litre 12 valve cams. In Australia the 164 Q was a five speed manual with a higher output 12 valve motor (215 HP I think). The cams had higher lift. I want to know how to recognize them.
Old 05-14-2007, 05:05 AM
Ah!
Can't help you then!
Not sure what the difference is between the regular 164 cams and the QV/S cams.
Tim Annett
Cincinnati
'04 Jetta GLS 1.8t
1983 Spider Veloce
1985 GTV-6
1986 Spider Veloce
1990 VW Corrado G60
2000 BMW 323i
Old 05-14-2007, 05:08 AM
GTV6PASSION GTV6PASSION is offline
Send a message via AIM to GTV6PASSION
OR are you thinking there are Q cams and GTA cams. What kind of car do you have?
Old 05-14-2007, 05:16 AM
oz3litre's Avatar
I have a 1988 3 litre 75. I was told recently by someone who may have known the original owner that it had Q cams put in it, but I don't know if it is the case or not. It certainly goes well. I have to take the cam covers off in the next few days to replace the spark plug seals and I want to check the cams out, but I don't know what to look for.
Old 05-14-2007, 06:01 AM
The Q are quad cams 2 intake 2 exhaust. It would be impossible to use quad cams in a 12v.
Old 05-14-2007, 06:52 AM
oz3litre's Avatar
There might be some confusion with the model designation in different countries here. As far as I am aware there was a 12v car here with hotter cams and higher power and a manual gearbox. Most people call them a 164 Q in Australia. A friend of mine has one and it is definitely not a 24v. They are not very common because most 164s in Australia are autos. Those are the cams that are sometimes fitted to standard 12v engines to tweak them a bit.
Old 05-14-2007, 07:07 AM
Alfissimo Int.'s Avatar
Registered Alfa Addict
There is confusion. 24V and 12V are totally different beats and when we are talking a 75, we are talking 12V so,
The 164 12V QV cams will fit without issue in the standard 3L 75.
They have a longer duration and produce more Hp. The cams will produce more high end torque and powe unlike the standard cams which tend to have most of the power on the low end.
They are a great upgrade. Your looking at close to 190Hp with the cams. The other difference between the motors are the pistons.
Standard cams:
Intake duration: 280˚
Exhaust " : 264˚
QV Cams:
ED: 277˚
Hope that helps, it was a breif explination!
Any other questions please let me know?
Ciao!
Jason
Jason Minos
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 05-14-2007, 07:08 AM
joey joey is offline
yep, our Q cams are the 'S' cams referred to in the states.... different model naming b/w countries...What u are thinking about is the QV - quattrovalvole (4 valves)
corry can't help.. but good question....
Old 05-14-2007, 07:12 AM
junglejustice's Avatar
junglejustice junglejustice is offline
Jason, not higher lift, longer duration BTW...
Any way - hey boss, what you are referring to are 164 "S" cams...
Within the earlier model range, the "S" version (here in the States) had a cam in it with slightly more duration and a standard lift. The 12 valve cars (from the carbureted Alfa Six, to the GTV6 2.5, to the South African GTV6 3.0, to the Milano/75 2.5 litre cars to the Milano Verde/Americano 3.0 litre found all over the world and then the early 164 cars (90 through 1993) all ran engines that at least generationally are part of the same "family" of engines - V6, 12 valve, single over-head cams per bank.
As far as I know (at least for the cars from GTV6 through Milano/75 and on to the 164 range), there were two basic cam profiles - Standard and then the "S" profile - known to you guys, Europe and South Africa as the QV 12 valve perhaps?
The S was the upper-end of 12 valve models and if indeed you have that cam in your 75, then yes, you have a bit more cam, but it is very mild. Claimed horsepower was 200 for the 164 S models over the 183-188 of the base 3.0 litre Milano/75 and early 164 cars however, that increase in horsepower was also attributable to higher compression pistons (10.0:1 in the S over the standard 9.5:1 of the base 164 and older Milano/GTV6 cars.)
Post the part numbers on the cams - that way you will find out for sure what you have!
As far as the later 24 valve generation 164 cars (1994 and 1995 here in the US) - they ran a 24 valve 4-cam motor and the cams are naturally NOT interchangeable with the older 12 valve engines! Cams were also the same for ALL of the models in this "family" of engines however, they did offer an upper end model (as with the S/QV for the earlier 12 valve cars) that was called the 164 Q.
The Q did NOT however have different cams in it, simply larger diameter intake runners with a claimed 18 horsepower improvement over a "base" 164 LS (Super to the rest of the world) 210 horsepower 24 valve engine.
Full-Race 3.7 Litre 24v Milano; Street/Track 3.0 Litre 24v Milano Verde; 2.0 TS '73 GTV; 6-speed 3.45 litre 24v Street 164 LS/Super; '06 Scion XB - Runs!
Old 05-14-2007, 07:27 AM
Duh, It's early! Your right. I even put the difference in duration....LOL!!
Thanks for catching that!
Jason Minos
