Old 04-19-2007, 01:01 PM
jcweho92Spider's Avatar
jcweho92Spider jcweho92Spider is offline
Send a message via AIM to jcweho92Spider
Have you used scratch remover for your alfa?!
has anyone use one of those? do they work? which one is the best?! any precautions? i am too scared to try...i just do not believe what i saw on the TV ads....
j
Jan C.
92 spider veloce!
West Hollywood, CA
Old 04-19-2007, 01:48 PM
lowmileage's Avatar
ReAlfisted 3/06
Do you mean for use on the convert window or the paint? If you mean for the plastic window, I have another vehicle that I used someones scratch remover on and it did basically nothing.
1973 GTV - bought 3/06
1969 GTV - sold in '72, hope you're still OK.
"I've shot 630 elephants and 63 men, and I regret the elephants more." Arthur Jones.
Old 04-19-2007, 01:53 PM
rgrimm's Avatar
rgrimm rgrimm is offline
If they're deep scratches down to the primer or metal, the scratch remover will do nothing. If it's a very shallow scratch, it "should" work similar to a polish.
Roger
1981 Alfa Spider, red
Old 04-19-2007, 02:06 PM
lowmileage's Avatar
ReAlfisted 3/06
I'd suggest that if you use rubbing compound on paint, I'd make sure it is the polishing compound (fine white stuff) and not the abrasive rubbing compound. Even then I'd go easy so as not to take off too much paint.
Old 04-19-2007, 04:49 PM
yeah, i was refering to the paint scratch removal..i guess no one really recommanded it..
Jan C.
92 spider veloce!
West Hollywood, CA
Old 04-19-2007, 04:56 PM
JoeCab's Avatar
JoeCab JoeCab is offline
There are many abrasive detailing polishes that will remove scratches.
Other products, commonly called glazes, act as fillers and will make smaller scratches much less noticeable.
When polishing, the general rule is to start with the least abrasive compound and see if it does the job. If not, try a polish one step more abrasive. Repeat the process until you find one that will do the job.
If you've used an abrasive polish, you will probably need to go over the car with a less abrasive polish as a second step to remove swirl marks caused by the first polish. Then use a glaze followed by a wax.
Old 04-19-2007, 05:54 PM
aralfa8589 aralfa8589 is online now
Joe's advice is on the money. I prefer to spend more time with a finer abraisive as it's a drag to go too far (this is a huge understatement). Try one of the major brands. If you go to a good store, the guys will look at your paint, and recommend the right product. Just remember not to "camp out" in one small spot.
Jeff Lang
'85 GTV6 3L, '89 Milano Gold
'91 164S, '91 164L
'89 Spider
'74 GTV project
