Old 03-21-2007, 06:54 PM
WithanF's Avatar
WithanF WithanF is offline
Tool Uses (Same post in Spider Forum)
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly-stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, "Yeou _ _ _ _...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or ½ socket you've been searching for the last 45 minutes.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal- burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 30 years ago by someone at Ford, and instantly rounds off their heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. Women primarily use it to make gaping holes in walls when hanging pictures.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts.
Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also, most often, the next tool that you will need.
It is a fierce, piercing shade of yellow, aglow with passion and defiance,
vibrating with the energy of a thousand suns, of thunder at dawn.
Have - 93 Spider Veloce (2006)
Had - 86 GTV-6 (1987-2006)
Old 03-21-2007, 08:48 PM
modena782002's Avatar
modena782002 modena782002 is offline
LOL! I had seen this before in another club publication a few years ago. Thanks for the laugh!
Nick D'Eri
1968 Fiat Dino Spider 2.0
2003 Saab 9-3 Linear
2008 Piaggio Fly 50
1977 Peugeot 103 Moped
Former Italians:
1992 164S 2002 - 2008
1981 Spider Veloce 2001 - 2003
1974 Fiat 124 Spider 1979 - 1981
Dad's Former Italians:
1962 Giulietta Spider 1964 - 1969
1969 Berlina 1750 1970 - 1971
Dignity...at all costs
Old 03-21-2007, 09:06 PM
WithanF's Avatar
The engine hoist is my favorite.
Old 03-21-2007, 09:20 PM
Dan Walker's Avatar
Dan Walker Dan Walker is offline
Dan Walker
Thanks! I needed a good laugh tonight!
Dan Walker
Old 03-22-2007, 09:25 AM
GianniB's Avatar
GianniB GianniB is offline
It's an old Peter Egan Road & Track Side Glances (the only reason to read R&T anymore IMHO).
Cheers,
John
Bothell, WA
[URL=http://home.comcast.net/~ccburrows/index.htm][COLOR=Blue]1973 2000 GT Veloce[/COLOR][/URL]
2005 Mini Cooper S
Keeper of the [URL=http://gtvregister.googlepages.com/][COLOR=Blue]105/115 GTV Register[/COLOR][/URL]
Old 03-22-2007, 09:30 AM
lowmileage's Avatar
ReAlfisted 3/06
ha ha Could have told you of any one of them if you had asked
1973 GTV - bought 3/06 (quiet, he's asleep for the winter)
1969 GTV, #AR1530021 - sold 10/72
Old 03-22-2007, 10:40 AM
Palmer's Avatar
Palmer Palmer is offline
I have them all, somewhere.
[FONT="Comic Sans MS"][/FONT]
Regards,
Jeff.
Growing old is mandatory; growing up is optional.
Old 03-22-2007, 10:55 AM
Gordon Raymond's Avatar
Gordon Raymond Gordon Raymond is offline
Every Alfa mechanic has used all these tools in the manner discribed. I think the metric tap should be included as a device used to permanantly plug holes in any non replaceable part as it snaps off. Replacement metric taps are also available from the "Snap-Off-Man", but he never shows up unless you are very busy. Gordon Raymond
Old 03-22-2007, 02:54 PM
The table saw hit home with me. Literally. Actually it was a radial arm saw. As an inexperienced twenty-something, I tried to rip a 1 x 4 lengthwise, and proceeded to rip it in the wrong direction. The board was quickly ripped from my hand, and continued right thru the wall adjacent to the saw. Nice clean hole it was. Looking back at it, I'm lucky to have all my fingers.
Nick D'Eri
2008 Piaggio Fly 50
Former Italians:
