07-20-2006, 11:54 PM
Originally Posted by Insoc
I assume Floor mounted pedals will work with this system, since the first test mule was one? Just asking since this is the final product...
James
It appears that the system fits well on Bryan's GTV...........with floor pedals.
07-21-2006, 05:20 AM
Hello again Dan,
I have mislead you then. I removed the front resonator, which is like a mini-muffler. It is a pass through muffler, with holes in the pipe, and outside those holes are fiberglass, steel wool, whatever they put in those things. So the exhaust would pass through and expand through these holes into the packing, and etc...
The expansion at this stage in my exhaust system with a Sperry Stage Five head was not good, too much back pressure was caused, and I had to remove it and installed a pipe in its place so the engine could breath better, and breath better it did. My seat of the pants engine diagnosis was confirmed that I had a problem when we discovered the hotspot in the front resonator, and there was no evident blockage in the resonator after we removed it.
I hope this is clearer.
James
1970 GTjr : 2000 Lotus Elise 111S
07-21-2006, 05:25 AM
Hello Biscione,
I don't want this to mislead people with standing/floor pedals. What I have and I assume Bryan does as well, is a Hydraulic standing pedal system, which is different then the cable clutch standing system.
By looking at photos, I do not think this Magnaflow system will work on cars with standing pedals that have the cable clutch, the linkages will be in the way...
However, standing pedals with the hydraulic linkages I believe and it seems confirmed by Bryan, (I look forward to his pictures for final inspection) will be ok, as the linkages are farther away from the chassis rail.
James
07-21-2006, 07:57 AM
Originally Posted by Biscione
James
Still to be determined. It clears, but barely. It did not seem to rub, but the clearance is VERY close, probably 3-4 mil. I have only driven it once, but I will continue my reports asap. I should meet with Simon either tonight or tomorrow to have him take a look and get his feedback.
Fast, Cheap, Reliable. Pick any two.
07-21-2006, 09:51 AM
Congrats, looks like a great system! I still have my parts in their boxes, waiting for putting my poor car back together. The bottomside of mine is *starting* to look like vintageveloce's...coating it with bedliner now...
I hpoe my custom built Magnaflow system is as nice as this one has turned out!
Current:
74 GTV
Former  :
88 Milano Verde
78 Alfetta Sedan
87 Milano Verde
70 GT Jr. 1300
[URL=http://www.flickr.com/groups/scuderiano/]Scuderia Non Originale Flickr Group[/URL]
07-21-2006, 03:39 PM
Hello Biscione,
Looking at the pictures of Bryan's engine compartment, it appears that he has a brake fluid reservoir but not a clutch fluid reservoir; so I would assume that Bryan has the cable clutch mechanism.
07-21-2006, 04:34 PM
I believe I have the cable clutch mechanism you are referring to. The exhaust goes to the side of it by a few inches, but wraps around very near the "box" for the pedals. I'll post pics this weekend.
07-22-2006, 03:47 PM
the first pic shows the clearance between the pipe and pedal box. You can actually get a better view from above, I will try to post that soon.
07-26-2006, 01:16 AM
Hi Simon,
Do you think your exhaust system would fit my Junior Zagato which has a 1600 engine instead of the original 1300?
Cheers, Adrian
07-29-2006, 12:06 AM
Admin
Adrian,
While I am not familiar with JRZ's in short Id have to say no it won't fit right out of the box.
I do think that with some modification that it could possibly made to fit and depending on your local shops rates you might be ahead of the game with one of these sytems. Are you anywhere near So Cal? If yes maybee we could meet and try to mount a system on your car.
07-29-2006, 01:06 AM
Sound-bites please?!?!?!
Sprintn
07-29-2006, 09:09 AM
Here is my Blue at Magnafow... it was sick tho... bad fuel pressure to to a bad electric connection...
http://media.putfile.com/BlueRun2Sick
Red 1974 Spider (Restoring!)
Blue 1974 Spider (Polishing)
Red 1975 Spider (Parting!)
Black 1982 Spider (Parting)
1998 Jeep Grand 5.9 (Wheeling)
1987 Suburban 454.(Guzzling)
08-03-2006, 09:02 AM
When will it be available for GTs w/1600 cc engines??? Would any of the sections fit (for example, the middle/rear muffler)?
08-04-2006, 02:29 AM
Simon, could you please record an audio file of your car running with the Magnaflow? Thank you! BTW, the system looks wonderful!
Do you have any diagram of the exhaust system with all the dimensions etc? It's difficult for me to order the Magnaflow because of the high shipping costs. I am considering of building such a system here in Greece so it would be nice for me to have the detailed diagram of it and make something similar. Thanks!
Theo
Alfa Romeo 2000 GT Veloce, 22 July 1971, #1803
+ an Echidna into my mind...
08-04-2006, 08:16 PM
flange fit
How have the flanges been lining up on those systems you all have installed so far? I got mine in the mail this week and am ready to start wrenching, but the flanges look a little out of parallel to me which seems odd. The OEM exhaust that I just took off wasn't like that, and I worry about putting much stress on the cast iron to make it fit. Should I worry, or just bolt it all up tight and forget about it? Opinions?
