#136 (permalink)
Old 04-18-2007, 12:46 PM
Keyspider's Avatar
Fiddling about on my computer today, I found a pretty good comparison video which shows a back-to-back Dyno run on my Blue Spider.
The car was sick when these were done, due to a bad electrical connection on the starter solenoid causing the Fuel pump to slow and the resulting low fuel pressure.
Its a pretty valid sound bite, as its the same car, same camera, and same place.
Run One is with a stock system with a Aftermarket replacement single Ansa Tailpipe.
Run Two is with the Magnaflow System fitted. The misfire was worse here, but the difference in sound is clear!.
Note he stopped at about 4500rpm... it gets a WHOLE lot nicer at 5k+
I will be posting a better video soon, now I know how to do it, but until then I hope this helps!
Red 1974 Spider (Restoring!)
Blue 1974 Spider (Polishing)
Red 1975 Spider (Parting!)
Black 1982 Spider (Parting)
1998 Jeep Grand 5.9 (Wheeling)
1987 Suburban 454.(Guzzling)
  #137 (permalink)
Old 04-19-2007, 07:21 PM
67GTV's Avatar
Originally Posted by green 69 gtv View Post
Although IAP is waiting to see how I work things out, it is likely that they sold me a set-up for a Berlina since I had to shorten it by about 8". Now all the hangers line up reasonably well but the first hanger on the exhaust (the main one that bolts to the horizontal, 2-bushing plate hanging off the transmission) rests about 1" higher than the mounting plate on the tranny. I can get the 2 pieces to mate but only with considerable torture to those rubber bushings which are new. New motor mounts so that isn't the problem. Are these 2 mating surfaces supposed to line up better without much force?
I was thinking of disconnecting all hangers and applying downward pressure on the tail pipe, perhaps with the system hot from running to operating temp first, to try to line things up better. Is this a really stupid idea? High likelihood of cracking header? Since I only have 1 place where there is a pipe clamp, I have very few options for making simple corrections by loosening/retightening different exhaust segments.
John
Before my GTV was selected for the first MagnaFlow prototype, I purchased an exhaust system from Centerline. I believe it was the same CISAM brand. In any case, I spent a whole weekend under my GTV struggling, swearing and sobbing. I spent so much time under there that I actually fell asleep at one point!
Once together, there was no way to get the whole thing to fit properly. I called Centerline the following Monday . . "oh yeah, you may need to cut six to eight inches off the front section to get it to fit." I still have that 8" unpleasant reminder. The system almost lined up to their mounting points after the cut. I found that twisting the front and center sections where they met, helped a great deal. I was finally able to get the bolts through the front bracket. My rear hanger was no longer vertical, but it seemed to be acceptible.
After I got the call from Simon, I spent another weekend putting my original holy system back on. Therefore the first dyno runs were a true comparison of stock to MagnaFlow systems.
Kai Schorr
105.36 : 1967 Giulia Sprint GT Veloce
  #138 (permalink)
Old 04-20-2007, 09:08 AM
green 69 gtv's Avatar
Originally Posted by smestas View Post
John,
Are you referring to the Magnaflow system that is the topic of this thread?
My original post to this thread referred to problem I'm experiencing fitting stock systems, and how the geometry tolerances vary by GTV car year. I had suggested that this might be something to look into with the magnaflow system. However, my most recent post was a reply to 67GTV, who had similar problems to mine using a stock CISMA system. Sorry if I've wandered too far from the original thread topic.
John
  #139 (permalink)
Old 04-20-2007, 09:23 AM
Keyspider's Avatar
I posted the videos of the sound bites.... and nobody has commented!
Just kinda concerned.. can anyone/everyone hear and see them... or did I do something wrong?
  #140 (permalink)
Old 04-20-2007, 09:48 AM
exhaust sound
The audio is good enough to hear a clear difference although it is hard to know what the sound would be like when not in a garage. Overall the magnaflow was obviously louder and I liked it a lot. However, on the ansa clip, beginning around 34 seconds into the recording , the higher revs sounded more "classic" alfa to me. Just my personal bias.
John
  #141 (permalink)
Old 04-20-2007, 10:07 AM
Keyspider's Avatar
Thanks John, I was concerned that the way I posted it was not right somehow.
Your comment about the Ansa clip is a valid one. I would say that when I swapped from the original style rear muffler to the Ansa, it actually was quieter, deeper and more mellow. I liked it.
I will say that the Magnaflow is much deeper sounding, and in the confined space of the Dyno seemed a little louder.
On the road it is awesome!
It has a deep note missing from the Stock system, and dare I say it sounds a lot more "manly" than before at low and mid revs. At high reves the mechanical noise is still there, but the exhaust not makes your hair stand up!
As I posted above the car was very sick that day and it actually broke down on the way home, and I had to get it flatbedded!
Here is the thread on what happened.
http://www.alfabb.com/bb/forums/electrical/27451-complete-electrical-failure-solved.html
Anyway, please note that in clip 1 the car was ran to the redline and in clip 2 the Tech killed it at about 4500rpm because he was concerned.
This weekend I will try to do a better clip from inside and outside the car.
  #142 (permalink)
Old 04-20-2007, 11:13 AM
Bill77's Avatar
Great soundclips, Keyspider! Definitely looking forward to any new sound/video clips so I can "desk drive" an Alfa.
  #143 (permalink)
Old 05-29-2007, 04:56 PM
Biba69's Avatar
Smestas, I know what a pain it is when someone wants only a part of a unit, but...
Could/would you sell just the front resonator? And if so, will stainless weld to just play old exhaust tubing? I have a vintage Euro exhaust on my '75 Alfetta GT and have managed to keep it alive except for the resonator. It is roughly 4" diameter x 9" long. When having a new muffler installed or parts welded up, I always ask the muffler shop if they can replace the resonator. The answer is always no.
If so, how much?
Biba
  #144 (permalink)
Old 06-16-2007, 11:40 PM
Where can I find the recording? I'm curious to hear the music before I write the check. My '74 GTV sounds anemic, even with the last muffler removed, a straight pipe to the rear and a resonator tip. Yuk.
Thanks!
Don
  #145 (permalink)
Old 06-17-2007, 12:54 AM
smestas's Avatar
Admin
Administrator
Send a message via AIM to smestas Send a message via Yahoo to smestas Send a message via Skype™ to smestas
Don,
You can get a slight idea of sound from this clip although the test car was not running 100% hence the hesitation and popping.
Simon Mestas
Help support AlfaBB
  #146 (permalink)
Old 07-30-2007, 12:30 PM
smestas's Avatar
Admin
Administrator
I'll be going to Monterey for the Historics weekend coming up. If anyone is interested in a system I have space to bring a few up to save on shipping.
Simon Mestas
Help support AlfaBB
  #147 (permalink)
Old 07-30-2007, 08:11 PM
pathung's Avatar
Black is Faster...
The boxes are quite big (i.e. expensive to ship), so Simon's doing everyone up here a nice favor bringing them up!
Patrick Hung
'59 Giulietta Sprint * '63 Giulia Spider * '67 Sprint GT Veloce
Costa Rica & Taiwan SNO Chapter Director
VeloceSpace Restoration Parts
Sprint Racer Build Photos
Vintage Alfa Registers
  #148 (permalink)
Old 08-04-2007, 09:06 AM
iachella's Avatar
Can one just purchase the front stainless steel pipe with the fitting to the exhuast manifold? I acquired some time ago two magnaflow mufflers that appear to be the exact ones in this set. With the front piece, I can essentially get a shop to install it.
Stefano
Concord, CA
iachella [at] gmail [dot] com
  #149 (permalink)
Old 08-04-2007, 01:30 PM
smestas's Avatar
Admin
Administrator
Stefano,
I only have complete sets for sale. Sorry.
I do however know that Anthony (italcarguy) did an install and has a extra front section he might part with. They didn't use it because the car had headers. Id call him at their shop and ask him if its for sale.
Here is their shop information
Simon Mestas
Help support AlfaBB
  #150 (permalink)
Old 09-03-2007, 12:11 PM
Rala's Avatar
Member
Sorry 11 pages of posts has me flumuxed. Are the kits stilll available, and how do I order 1 for my Spider?
Bob
Bob L
Don't argue with success
'78 Spider Veloce
