Go Back   Alfa Romeo Bulletin Board & Forums > General Forums > Anything about Alfa Romeos and AlfaBB.com
View Poll Results: Your tensioner type on that 12v V6 Alfa engine
Original Oil Fed OEM Tensioner 7 29.17%
Oil-less modified oil fed tensioner 4 16.67%
New style spring loaded mechancial tensioner 13 54.17%
Fixed type such as Zat tensioner 1 4.17%
Multiple Choice Poll. Voters: 24. You may not vote on this poll
Old 02-08-2006, 08:21 PM
What kind of tensioner is your 12v V6 running?
Tell the truth now, just what kind of tensioner do you have installed on your Alfa 12v V6 engine?
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Old 02-08-2006, 08:44 PM
nizam's Avatar
nizam nizam is offline
Steve - I have two Verdes, both are on the "Oil-less modified oil fed tensioner" (only one vote though)
Old 02-09-2006, 01:07 AM
Richard2 Richard2 is offline
Well, I voted Oil Less modified. But its fixed. Only uses the oil spring to set the tension when you adjust it every 15,000.
I think if I had to do it all over, I'd rebuild the oil filled. I had absolutely no problems with it when i changed it out with the belt due the leakage scare. Why not just rebuild the oil filled everyother belt change like changing out the water pump every other belt change?
Richard2
1991 164B Silver Daily Driver
Old 02-09-2006, 05:36 AM
I may do that Richard on one of my spares as I have a OEM factory kit in stock. Point of info too is that 24v tensioner bearing pulley the same as one for oil fed unit but you have to press 24v bearing off 24v inner pivot piece and do same with old 12v center pivot piece and then press 24v bearing onto 12v unit.
Virginia Beach, VA
Old 02-09-2006, 05:44 AM
I wonder how good the seal would be around the oil supply hole. Mine and yours too I suspect was drilled, tapped and plugged for the mechanical tensioner. Even if I can get the plug out, which is in with Locktite, the hole is bigger than original.
Richard2
Old 02-09-2006, 05:47 AM
dretceterini's Avatar
dretceterini dretceterini is offline
I don't have one of these cars, but as an engineer, I prefer a mechanical to a hydraulic device.
Old 02-09-2006, 05:58 AM
If need be we could remove plug, drill hole in it and reinstall it couldn't we? I used removeable blue loctite if you used red it maybe hard to remove.
Virginia Beach, VA
Old 02-09-2006, 06:00 AM
How could an intelligent engineer, or even a non intelligent engineer exist without "one of these." Are you sure yor an engineer? You'd better show us your credentials.
Richard2
Old 02-09-2006, 06:04 AM
Steve
If I remember right, I used red.
Richard2
Old 02-09-2006, 06:15 AM
Shame on you the bulletin calls for red. I used red one time on an aircraft hydraulic filter module (called for in factory manual) but it is a bear to remove parts later on.
I guess if it won't come out you could drill through plug in place with grease on drill bit to capture filings and use vacumm cleaner to suck out hole afterwards.
Virginia Beach, VA
Old 02-09-2006, 06:27 AM
Why not just drill out the hole and use a helicoil??
Old 02-09-2006, 10:17 AM
The hole is just an open return oil passage (no threads in it before mod) when oil fed tensioner installed. What Richard is concerned about is, since it has been drilled out a bit, will the backing plate 60507320 and O-ring 60513407 that lays in backing plate hole still seal return oil flow from outside world.
Oh by the way seal kit number is 60777065.
Another more major problem for the people who have mechnical tensioner installed is finding all the pieces that goes with oil fed tensioner especially the hollow bolt 60539559 that you need to convert back to oil fed set up.
Virginia Beach, VA
Old 02-09-2006, 10:37 AM
Denny164l Denny164l is offline
Unhappy I Dont Know!!!!
I wish I knew because I want to replace the belt water pump tensioner ect. but I dont know what type it uses. "92" 164L
  #14 (permalink)
Old 02-09-2006, 11:22 AM
Depends on who done what to engine. You will need to pull wheel, fender liner, bottom and rear lower timing belt covers to see tensioner.
Virginia Beach, VA
  #15 (permalink)
Old 02-09-2006, 11:47 AM
nizam's Avatar
I can understand the problem folks face when they want to get it "back to factory specs", which was imperfect to begin with. I doubt Milanos, GTV6's or 164's will be put on pedestals like the 6C2300 so why bother? The hydraulic tensioner - sans the hydraulic
