you should post in your existing thread so everyone has the full history.
if dealing with a mixture of aluminium and steel corrosion from the studs,pulling alone wont shift it. you need to dissolve it with phosphoric solution, rattling it and diesel soaking. It always works, but takes time.
you need to find out if the material spec in the head and piston crowns contain any appreciable amount of magnesium. if they do, any acids are a bad move. If the heads contain no more than 2-3% magnesium, which is a common strengthening percentage, then 70% phosphoric solution down the stud holes over several hours , followed by thorough flushing should shift the corossion. you will need to repeat this several times. the phosphoric will dissolve the rust on the head bolts and theory is it will help to break the seal. Along with this you might try rattling the area with an air rivet gun on a block of wood at the same time. keep the power low so as not to crack the head. short bursts only. the vibration will help to break loose the desolved corrosion. be sure to flush regularly with the carb cleaner. you must throughly de-grease before putting phosphoric in, or it wont react.carb cleaner is good for that too. once you have done this method a couple of times, soak the stud hole with diesel for a day, then go for it . have an assistant rattle the area again intermittently, whilst you lever, and it will eventually give. you may need to repeatedly seat the head and unseat it to help it past the softened corossion.
test a small clean area with the acid first. if there is any minor fizzing or bubbling whatsoever, then u cant use this method.
