Old 05-22-2008, 07:33 AM
RAGs's Avatar
RAGs RAGs is offline
Alfisti
Post GTV-6 Aluminum Radiator Option ~ Revisited!!
Can't take credit for this but ...
This does seems like a decent fit for $180 (albeit fan and temp sensor to be worked out).
JEGS 52010 - JEGS Universal Aluminum Radiators - JEGS
Stock is 29 x 16 and JEGS is 28 x 16.5. It seems to have a 2 row crossflow design and compared to IAP's $500+ unit, this might be an option.
Just though I would pass it on.
Red '88 Milano Verde - When you just gotta to have 4 doors...
Black '86 GTV-6 - The one that got it started and needs to be re-started...
Yellow (soon to be) '67 Duetto - middle of delayed restoration...
--- Honorable Mention ---
Burgandy '94 Volvo 850 Turbo - Groceries ...
Emerald '90 VW Corrado - The Backup ...
Brown '71 C10 Stepside w/ a 350ci and 3 on the column
Old 05-22-2008, 05:05 PM
MarcusHMM MarcusHMM is offline
I have been eying that one and also a similar one at Summit. And Griffin has a stock one also that should be a very nice fit with bungs for sensors. I have a Griffin that was custom made for my GMC and it is a great radiator but it was over $750.
Marcus
82 Alfa
4 GMC Motorhomes
and not enough time or money.
Old 05-24-2008, 08:56 AM
HDuncan HDuncan is offline
I installed that radiator (the one from JEGs) in my GTV6 last year and have had no cooling issues since even when it was 104°F last year. I purchased the fan and fan controller from JEGs as well, however the last time I checked JEGs no longer carried the same fan. The fan I used was a 16" SPAL (p/n 30100400) and can be found on SPALUSA's web site. I would use that fan since it was only a little over 2" thick and there is not much room there for anything thicker. As far as fit goes, there was a tab on the lower left of the radiator well that needed to be bent down for clearence to allow the radiator to sit all the way down in its well. The lower radiator hose needs to be stretched slightly to fit , but that was all.
Old 05-24-2008, 09:16 AM
ToonRboy's Avatar
ToonRboy ToonRboy is offline
That's great info! Hell, I spent ~$286.00 for a stock radiator 8 years ago! Now they're about $450.00! So, very close to the cost of the aluminum ones. Anyhow, crankcase did a nice job with one of these on a Milano: Three hole aluminum radiator
Old 05-24-2008, 05:45 PM
Just for clarification, the JEGs radiator for a GTV6 is p/n 555-52010. Apparently the inlet and outlets are reversed between the Milano and GTV6.
Old 05-30-2008, 05:21 AM
Alfacliff Alfacliff is offline
stuv904 is a spammer, spam reported
cliff
Old 06-10-2008, 07:00 PM
block's Avatar
block block is online now
Jegs Radiator install.
So thanks to this thread, my radiator troubles are over! After replacing my leaky one with an even leakier one, I knew something must be done for less then IAP's $750 solution. I was looking at a similar one from summit but the jegs seemed a better match.
Here's what I did...
The Jegs radiator is a bit higher then stock, but worse, the lower inlet sits much lower then it should. I had to use a dremel with a nice cut wheel to notch out some excess metal around the cross member to allow it to drop down far enough to get remotely in. The first pic is a fuzzy look at this area (it was not I who tried to tow the car by the tie down hooks).
Being a cheapo, I decided to try and save my stock fans. However it became vary obvious that, with the way this radiator was sitting, they would not mount where they are supposed to be. Still being a cheapo, the conclusion was that since the A/C doesn't cool, the condenser will be swapped for fans. The problem there is that the fans are now going (pulling) the wrong way. This was fixed by reversing the wires in the their clip's. Black to white, white to black and now the fans spin the other (push) way. Heck yea! The second photo show's the fans in their new home.
Now for the fun stuff. I had to make some hoses. The Jegs radiator has a 1 and 3/4" inlet in the lower instead of our 1 1/2" hose. Now, there is a T-junction that connects a hose off the water pump to the lower inlet hose and the over flow tank. And the hose from the water pump goes from 1 3/4" at the pump down to 1 1/2" at the junction. There is probably a better way to do this then what I did...
So, I simply took an exhaust fitting that went from 1 1/2 to 1 3/4. Got it at Pep Boys for a few dollars. While there, I got a random 1 3/4 radiator hose with a good curve to it. I some how lost the photo's of all this stuff however, a lot of trimming and squeezing took place onALL the Radiator hoses. I will try and get a photo of the area if any one is interested. The top hose is the right size and was vary non-dramatic.
Next was to get every thing secured in place. Some metal and nut&bolts was purchased from the Home Depot. A strip was mounted down low where the A/C cooler used to bolt. Though I bought a metal strip with holes in it, I had to drill a couple for this myself. The fans however bolted right up. At the top, I just twisted some bits up for a 3 point mount. Well, they ain't going nowhere so no biggy. Next photo from the front!
For the radiator, same metal was bent to a U type shape and positioned at the original mounting point. A shorter bolt is needed then the original.
For the time being, I have just jumped the fan switch sensor wires together for an fans always on scenario. However,will be resolved soon.
Despite not having any numbers off the temp gage, everything seems splendid and staying right cool in the 90 degree heat that just hit. Last pic of a shinny alloy radiator in place (so shiney it caused glare)!
eb
85 Spider 85 GTV6 71 GTV
