Old 05-13-2008, 05:35 PM
Giorgio68's Avatar
Giorgio68 Giorgio68 is offline
GTV6 headlight conversion relay
I am in the process of replacing the sealed beam headlights into Hella H4, H1 halogen headlight.
I would like to ad some relays, has anyone done this other than (hiperformancestore.com), I would to know the process what type of relays to use and the whole procedure, so I can get enough voltage to the headlight before burning anything on the system.
I did a quick test with the voltmeter I am getting 13.5V on the alternator vs 11.7 on the headlight.
Giorgio
[SIGPIC][/SIGPIC]
{Oo==V==oO}
Currently:
'75 Giulia Nuova Super 1300 Blu Olandese
'71 Euro Berlina 2000 (on a restoration process)
'85 GTV6 Nero
'87 Milano Verde
'87 Milano Platinum
{OO==V==OO}
Old 05-13-2008, 07:42 PM
al_cam al_cam is offline
Giorgio,
Electrics for cars are usually designed to run at the alternator volts 13.5v - 13.8v, so you're not going to burn out the globes. You need to select a relay to handle the current the globes will draw. Watts as used by the globes is volts x amps, so divide your total amperage by the volts and get a higher amperage relay. Use one relay for both globes, so multiply the watts by 2. For example 150 w globe? 150x2=300W, 300w/13.8v=21.8A. You need a relay that handles more than that. Typical car relay is 30A. Although if you are getting close to the rated current for a relay, they tend to get hot and melt. If you were using globes higher than 150W each you'd be better off using one relay for each globe.
Al Campbell
Old 05-14-2008, 04:41 AM
alfaparticle alfaparticle is offline
There is an ebay seller that has sets of 4 relays for about $15. I have them installed on my Milano for E code lights.
79 Spider Veloce
88 Milano Verde
88 Milano Verde
Old 05-14-2008, 10:53 AM
GreyGTV6's Avatar
GreyGTV6 GreyGTV6 is online now
I'm about one month away from doing mine. From my planning it should be a fairly painless job. On the L/H bulkhead there is a direct feed from the battery that could be fed into the relay while the original feed to the lights will be used on the coil side to pick the relay. I would like to find some fuses to mount to the bulkhead rather than use loose in-line relays. I have new head lights so I'm keeping them stock because I feel with proper voltage and grounding they should suffice. Please keep us updated and post pics if possible.
I cleaned my tail-lights and polished the reflectors of one to compare the difference with my other light and the difference is dramatic. The L/H light is bright and crisp, while the R/H is dull as you would expect from a 20 y/o car.
Steve.
And on the 7th day, he made Alfas....
Is a dream a lie if it don't come true
Or is it something worse - Bruce Springsteen (The Boss)
Old 05-14-2008, 11:15 AM
Giorgio68's Avatar
Originally Posted by al_cam View Post
Giorgio,
Al Campbell
Al,
I will be using 30A relay per each side. I found this diagram how to set up the relays, it is not for Alfa but the idea is the same.
[SIGPIC][/SIGPIC]
{Oo==V==oO}
Currently:
'85 GTV6 Nero
'87 Milano Verde
'87 Milano Platinum
{OO==V==OO}
Old 05-14-2008, 11:46 AM
ToonRboy's Avatar
ToonRboy ToonRboy is offline
I bought mine from "paylesstellfriends" on ebay. eBay Motors: FIAT / ALFA ROMEO HEADLIGHT RELAYS , You'd be surprised at how much brighter the stock sealed beams get just by installing relays (at least on the GTV6). Nice clean voltage going to the headlamps rather than through all the oxidized connections in the steering column. I may swap to H4/H1's, but I just installed fogs under the bumper on another relay to help in those rural stretches... Daniel Stern Lighting has a couple of nice diagrams. Relays: WHY AND HOW TO UPGRADE YOUR HEADLAMP CIRCUIT
Old 05-14-2008, 01:59 PM
jjeffries jjeffries is offline
Google "Daniel J Stern Lighting Consultancy"; he has exactly what you needs at a very reasonable price, using highest quality european relays and clear instructions.
Old 05-14-2008, 02:33 PM
Giorgio68's Avatar
I already have everything I need including the headlights, just waiting for the right time to do it.
FYI one before your thread had already mentioned about Daniel Stern.
Giorgio
[SIGPIC][/SIGPIC]
{Oo==V==oO}
Currently:
'85 GTV6 Nero
'87 Milano Verde
'87 Milano Platinum
{OO==V==OO}
Old 05-14-2008, 03:15 PM
Giorgio,
That'd work fine except I'd put a second fuse in for the low beam lights, in the red wire, taking it back to the battery positive. That way if a fuse blows, you don't loose both sets of lights. Also in that case you've got four high beam globes going through one relay and one fuse, so rate your fuse accordingly.
Al.
Articles
