Old 05-04-2008, 12:33 AM
Grant's Avatar
Grant Grant is offline
79 Alfetta gas mileage
Hello all,
I recently drove to Bimmerfest in Santa Barbara from San Luis Obispo after leaning out the Spica a few nights before. So, I figured I got around 20 mpg in mixed driving.
What else should I be checking to improve gas mileage? Do these cars have a vacuum advance on the distributor? According to the AROO's Spica Tune-up guide and Braden's Alfa Bible, the Spica should have a lever with 3 settings for Normal, Cold, and Freezing climates. My Spica has no lever, instead there's just a flat head screw where I think the lever should be, and no markings for the different temperature zones. Maybe my Spica is set for a colder climate?
Any tips?
The car has been impressively maintained the over the course of its life, including a recent tune-up and head work. Block has around 90K miles if I read the receipts correctly. Any tips at all?
1984 GTV-6 - 80K miles
Old 05-04-2008, 09:31 AM
rogerspeed's Avatar
rogerspeed rogerspeed is offline
You aren't missing anything, the early SPICA pumps had that lever, but very soon became non=adjustable. Asuming it isn't A/C or automatic, a heaDer and exhaust along with the right cams would get you a little better mileage.
'83 Rabbit LS Diesel,5spd,4dr,S/R
'67 BMW 1600ti/Alpina
And Looking For Another
www.resoles.com
"just say no to reductionism"
Old 05-04-2008, 02:20 PM
Trevlac217's Avatar
Trevlac217 Trevlac217 is offline
Last I checked I got 27 mpg with my Dellortos. That's assuming the odometer reads correctly. The tank was also burned off with many LONG idling sessions in the driveway while working out the tuning issues the previous owner left me with. I would expect the FI models to get better gas mileage.
-Jason
'79 GTV (Euro)
Old 05-04-2008, 02:45 PM
Grant's Avatar
Do the Euro Alfettas have higher compression ratios?
Old 05-10-2008, 04:05 PM
Grant's Avatar
OK, so leaned the Spica out quite a bit (just over 3/4 turns clockwise on the FCS) but I'm still seeing around 18 mpg with combined driving.
Are the Spica'd cars supposed to sputter and miss for a second after the fuel gets cut and coasting? Do you guys have missing when you first start the car until you "clear the plugs", or atleast, that's what it seems like it's doing.
Old 05-10-2008, 07:24 PM
superloaf's Avatar
superloaf superloaf is offline
grant, IIRC there is a fuel cut off solenoid for when you're decelerating & which can cause some sputtering/popping. mine sputters on deceleration but it sounds good--not like any major fuel problem. also, when starting, i have NO plug clearing issues or any other issues for that matter. you may be set rich or have some other problem.
i have some printed info which i downloaded from an alfa owners's club (somewhere in the northwest--portland?) which has a step by step instructions about how to set the spica correctly. i did mine a year & a half ago and ever since the car starts immediately, idles fast until warm, slows to normal idle speed, and runs absolutely perfectly. when the spica system is working correctly, it's really great! i think a lot of the problems come from the fact that changing one setting can change another setting so if you don't go in the correct order, you'll have troubles. my car ran well enough when i got it except that it was set super rich just so it would start when cold. i leaned it way out and then set ll the other settings as described in the instructions i have and ever since the car has been great, literally starting after 3 seconds of cranking after not being started in over a year.
i've been meaning to copy the spica tuning instructions for others since it isn't anywhere on the web anymore, so i'll do that next week so you can have a look. it is the best, the easiest, and the most comprehensive guide to the spica i've found anywhere.
also, do you have a wiring diagram for your car? mine had lots of solenoid wires detached which i had to trace and reconnect. the proper wiring and settings made my spica purr like it's supposed to!
bob
77 Alfetta Sedan, 87 Milano, 86 Porsche 944 Turbo, 87 VW Scirocco 16 Valve
Old 05-10-2008, 07:51 PM
Grant's Avatar
Hi bob,
My Fuel Cut Solenoid (FCS) is working just fine. I'm not sure how cutting fuel causes the backfire, but if that's how it's supposed to work, that's fine by me. I know it works because when I was adjusting the mixture again today, I forgot to re-connect the wire to the FCS and it was noticeably different when I abruptly lifted off on the throttle.
It's possible my ignition timing was way too retarded. The adjustment was almost to the end of the retarded position on the distributor column, and I was able to advance it quite a bit until I thought I heard pinging at around 3500 rpm, WOT.
I looked at the plugs, they weren't a golden brown color, looked a bit lean, which was what I was aiming for to try to get better MPG, but the porcelain was cracked on at least one of the electrodes. I don't think this was from the brief amount of time I was messing with the advance...it could just be that the plugs are old.
Unfortunately, I don't have a timing light at my school and my buddy that does is at the 24 hours of Lemons.
The AROO spica manual is located here:
Renting a Spica Adjustment tool
All you lurkers reading the forums, you'll have to create an account to download attachments.
Old 05-10-2008, 08:08 PM
superloaf's Avatar
grant, ok, that info is available. cool, because that is such a great piece of info. absolutely great. anyone with spica should follow that for a great running car.
grant, just for basic info, how did your car run when the FCS was disconnected? just curious as i've wondered if this was a good feature or bad.
bob
Old 05-10-2008, 08:58 PM
Grant's Avatar
All you have to do is unplug the wire going to it.
Unless you're careful with the throttle, the fuel cut can make the car a bit jump when it come on and off the gas. I think somehow the later Alfettas were less effected by this, as I remember reading a R&T article which talked about how much better the transition was than the previous year's car they tested (I forgot the actual years though).
With the solenoid disconnected, the car was less jumpy and there was no hesitation when it was time to get back on the gas. It actually made the car drive a lot better after decel. My car always hesitates for a second before it accelerates after fuel cut. For me, it's a worthwile trade-off for gas mileage, but modern EFI is much better at resuming fuel after coasting.
Old 05-12-2008, 03:07 PM
ckeen74 ckeen74 is offline
Hi Grant,
If you have a Harbor Freight nearby, you can get a timing light for pretty cheap (under $30, I think). To answer the mileage question, I got 24mpg over the drive from San Francisco to Seattle... I think my hand throttle (connected to a SureStart) was pulled out a bit since the cable snapped, and we were going up to about 5000 feet elevation, so I think that affects fuel economy too.
I'm running a used SPICA from APE and have a stock engine with a head with a relatively fresh valve job on it and 115K miles.
Chris Keen
'77 spider veloce - since 1991
'79 sprint veloce - since 2005
'97 Golf veloce - since 1997
Old 05-12-2008, 08:01 PM
Grant's Avatar
That's pretty decent. I, on the other hand, returned about 17 mpg again with mostly city and some freeway driving.
Factory literature states 19 and 25mpg for a 1975 GT.
I still haven't hooked up the wideband, I'm wondering if I"m running excessively rich on throttle tip in, or idle or something...where could all that gas go??
Old 05-13-2008, 09:05 AM
sfalfa's Avatar
sfalfa sfalfa is online now
Registered Loser
Grant,
I always chalked up the mileage to the hotter cams or engine work done on the car (Though I never found receipts for it - I'm 99% certain it's been done). The car is significantly more powerful than any Alfetta I've owned, especially on the top end, where it continues to pull stongly where other Alfettas run out of breath.
___________
Jeff B.
'75 Alfetta Sedan (rosso)
'69 Lancia Fulvia Rallye 1,3 S (rosso)
'92 Ducati 900SS giallo
gone but not forgotten
'79 Alfetta Sprint Veloce(luci del bosco)
'77 Alfetta Sedan (nero)
'76 Alfetta Sedan (argento metallizzato)
'86 VW Scirocco 8v
'72 Honda CB500/4
Pics! http://www.flickr.com/photos/13463758@N04/?saved=1
North American Alfetta Sedan Registry (work in progress): http://alfanaticsf.googlepages.com/
Old 05-13-2008, 01:10 PM
Grant's Avatar
Hi Jeff.
I'm wondering if the car pulls better up top just because of the shankle headers and lack of resonator? She's still a bit tepid under full throttle, but it's OK, I really like cruising around and running errands in it.
Unless the pump was modified by Wes Ingram or something, I don't think hotter cams would make the mileage any worse. The fuel delivery system is fixed, so, if I flow more air through the engine because of cams, the Spica won't know the difference, and just deliver fuel based on RPM, air temperature, and throttle load (I'm not 100% sure about the RPM tidbit, but I don't see how it could run well with out knowing RPM). So, if anything, I should get better mileage with hotter cams (that increase low RPM performance, like Euro cams would) because I should have to use less throttle to accelerate at the same rate. I'm in no way an expert, this is just what i've read so far.
I am planning on pulling the valve cover to seal up the gasket a bit, I'll check the cams out and let you know what I find! But, I still have a hunch it has stock cams
  #14 (permalink)
Old 05-26-2008, 05:02 AM
Trevlac217's Avatar
Sorry for the slow reply. I've been in training for the last three weeks. No, from what I've seen in my limited Alfa time is that the difference in the Euro engines of that year and the American models are the cam profiles and the use of carbs instead of spica. My car was advertised as having the 10.4:1 CR pistons, but that has not been verified.
-Jason
'79 GTV (Euro)
  #15 (permalink)
Old 05-30-2008, 05:19 AM
Alfacliff Alfacliff is offline
stuv904 is a spammer spam reported.
cliff
Articles
