Yeah, I know. Fuel pump switch is in the AFM. There is also a roll-over switch that turns off the fuel pump. This is my first GTV6 and I clearly recall hearing mine when switched to "on" or last position b4 crank. Car is currently up on jack stands with battery removed, so I cannot double-check at this moment. I'll get back on this.
...getting back to NOLA's problem, I once hit one of those "steps" at a crossroads where new pavement was just laid (at around 30-40mph) and suddenly my car (Milano Gold) started sputtering and I had to pull over. I checked all wiring and still, no start. Turned-out to be the ECU connector got loosened from the jarring it took! For what it's worth.
