Perhaps next time we can put it on the other way around and it will straighten itself :-)
Actually it was my fault: the centerpiece of the puller is shaped like -o- (cross section; into the "o" goes the main threaded bar and the puller arms were disconnected from the end of the "-"s) and on the first try, I positioned it so that its longer side was perpendicular to the piece of metal. So it basically tried to "cut" the metal in two in the middle, like the edge of a knife. When I saw how the metal was bending, I turned the centerpiece 90 degrees so the "edge" was parallel to the piece of metal, placing much less stress on it. And it didn't bend any further.
Currently: '74 Spider Junior 1600, '77 Alfetta GTV 2000, '79 Alfetta GTV 2000, '79 Sei 2.5 V6, '80 Sei 2.5 V6
