  #16 (permalink)
Old 05-10-2008, 07:14 AM
5yearplan's Avatar
does it run rough for a period during the warm-up phase, then die, or run fine then stall immediately?
I'd check the battery voltage while its running, see if anything drops off. Also I forget how the distributors work in these cars, maybe it's not advancing?
[SIGPIC][/SIGPIC]
You should buy my stuff: http://www.alfabb.com/bb/forums/showthread.php?t=44309
Restore and Engine Conversion:http://www.alfabb.com/bb/forums/showthread.php?t=46024
  #17 (permalink)
Old 05-10-2008, 08:22 AM
Lugnut's Avatar
Lugnut Lugnut is offline
I did some more searching around the board and I'm going to pick up a Bosch NOID test light so I can make sure the injectors are firing. Then I'm going to check the filter and the in-tank filter. There is a chance I'll get in there this weekend... maybe a small chance, but a chance!
  #18 (permalink)
Old 05-10-2008, 02:11 PM
GVVGTV6's Avatar
GVVGTV6 GVVGTV6 is offline
Sorry you haven't figured this one out yet, pulling the in-tank filter isn't very fun - I'd say to bypass the roll-over switch but usually when they act up it is all or nothing, the car will not start again.
The other one is the bosch fuel injection relay located at the top of the fire wall on the passenger side of engine compartment - new one is around $80 - these can be a hard one to diagnose - but if it has never been replaced it is most assuredly due.
GV
  #19 (permalink)
Old 05-10-2008, 10:27 PM
5yearplan's Avatar
yeah mine was weird, about every 4 or 5 times i started the car it wouldn't start, i had to unplug that double relay and plug it back in, and it'd start again.
[SIGPIC][/SIGPIC]
  #20 (permalink)
Old 05-13-2008, 01:57 PM
AAR71 AAR71 is offline
It would be easier if it died and stayed dead, wouldn't it?
There is a fine black wire that goes into the relay harness on the passenger side firewall. In my car it is grounded to the wiper motor case. It comes loose within the plug sometimes and gives the symptoms you describe. You can sometimes get lucky and create the problem by wiggling it with the engine at idle. Take it out, clean it and tighten up the terminal's grip.
I'd also suggest checking out the fuel filter near the pump.
Failing that, put the old coil back on. Coils will go funky straight out of the box. Your new coil/ballast resistor are wired right too?
  #21 (permalink)
Old 05-13-2008, 01:59 PM
Lugnut's Avatar
I must have missed this message before my last reply.
It runs great while it runs. No rough running or anything.
It fires up right away when cold, runs great for about 2 or 3 minutes, and then just suddenly dies.
  #22 (permalink)
Old 05-20-2008, 06:47 PM
Lugnut's Avatar
New update!
I jumped the double relay 88Y to 88D. When I do this, I can hear the whooshing of fuel coming up front and I can feel the fuel pump chugging when I feel it under the car.
When I start it, let it run for the 40 seconds or so til it dies, I can feel the fuel pump whirring away the whole time when the pins are jumped.
I tried it with the TTS unplugged, no change.
I move the arm on the AFM, I can hear the relay click. Changing the position of the arm or actuating the actual flapper doesn't keep it alive.
I have spark all the way until it dies.
WTF!!! What is there left to check?!
  #23 (permalink)
Old 05-20-2008, 07:17 PM
5yearplan's Avatar
well if the fuel pump doesnt lose power, see if the spark quits, or fuel injectors.
[SIGPIC][/SIGPIC]
  #24 (permalink)
Old 05-21-2008, 06:19 PM
Lugnut's Avatar
Ok, MORE updates!
I plugged in the noid light and the injectors cut out, causing the car to die!
What will make my injectors stop firing?
  #25 (permalink)
Old 05-21-2008, 09:30 PM
85gtv6 85gtv6 is offline
Lugnut,
If you haven't already done so, replace the two fuel injection fuses (5 and 8 usually). I had a similar problem and both fuses looked good but after I replaced them the problem went away. The reason was that one of them had a harline crack across it. See Greg Gordon's L-Jet tune-up page (about 1/3 of the way down.)
Good Luck
Jeff
L-Jetronic
  #26 (permalink)
Old 05-22-2008, 04:03 PM
Lugnut's Avatar
Fuses replaced. No change.
I adjusted the TPS so that I can hear the click once the throttle comes off idle. No change.
I adjusted the idle up and down, looking for any sort of difference. No change.
It seems I had a fluke start, where I started the car and revved up to 3k and held it there for a good minute. I released the pedal and got an irregular idle, UP, DOWN, UP, DOWN. Then it died. I haven't been able to repeat it since then.
  #27 (permalink)
Old 05-23-2008, 05:05 AM
Venci's Avatar
Venci Venci is offline
Send a message via ICQ to Venci Send a message via Skype™ to Venci
I had similar problem with my 2.5 Alfa 90. She was starting cold and runing a couple of minutes. Then the idle was disappearing and the engine stop. If I tryed the engine was starting again but without idle. I changed a lot of things but there was no effect. Finally i have found that the connector in red circle was loosen. My opinion is that your car sucks air from somewhere - some hose, the gasket of the throttle body or even the servo...
Alfa Romeo 90 2.5 V6 QO
Alfa Romeo Giulietta 2.0 Twin Spark
  #28 (permalink)
Old 05-23-2008, 10:36 AM
ToonRboy's Avatar
ToonRboy ToonRboy is offline
Interesting that none of the Alfa technical Advisors have chimed-in with any advice. Back in April when you wrote:
I finally got my GTV6 running this morning! New plugs, wires, coil, hoses, plenum couplers, battery... Fired it up and VROOOOM!! It's running GREAT! Lots of power, great idle, fabulous pull all the way to redline. Until it gets warm, that is...
I'd ask, how the engine ran before you replaced all these parts and why did you replace them? What coil, plugs, and wires did you install? When you have an unmetered air leak (like AAV for example), your engine will idle faster, which will cause you to adjust the idle down - thinking your idle adjustment is off. So, the engine will run OK, when the CSV is open, but will die when it kicks off (after thermo-time is up). Double-check your work for possible air leak somewhere (couplers?). Disconnect the AAV and plug the hose/s after your start and see if idle drops. Spray top of engine with starting fluid and see if idle jumps-up. If either of this conditions = true. You have an air leak. That's where I'd start. Remember, it's an old car and you could very well have one or more injectors that aren't up to snuff. Again. Car will run ok when the Cold Start Valve is spraying, but will be lean-out when it cuts.
  #29 (permalink)
Old 05-23-2008, 11:21 AM
Lugnut's Avatar
Ok, maybe my final status update here.
It's running!
I went and re-checked all of the grounds. It turns out I missed an important one: the injector harness at the valve cover bolt! It seems it had been crossthreaded at one point and was basically just sitting in there, finger-tight in the one thread it had left. I moved them to a different point, got them all cleaned up, and it started right up and stayed running.
I adjusted the idle with the car actually running and now it's rock-steady at a hair below 900rpm.
And to answer the last question, I picked up the hose kits from Greg Gordon and everything else came from IAP. The car was a non-runner when I bought it and I was just doing general tune-up stuff. Then it ran great for a couple days and acted up like this.
Like Greg says, Alfa attributes 80% of its problems to bad grounding. Anyway, it's working now.
Thanks, everyone, for all of your help.
Articles
