Old 03-15-2008, 05:18 PM
La Voce's Avatar
La Voce La Voce is offline
AnsArias
Lightbulb Idle speed/smoothness change with brake application
It really is necessary to get out and drive to learn your recent restoration's nuances. I notice that when I depress the brake pedal (Weber carb conversion) the idle speed drops down 200-300 rpm and becomes lumpy, and when I release the brake pedal, she pulls back up and smooths back out. Dang if I didn't realize it has probably been doing this all along while I chased "carburetor problems". I'm thinking the one-way check valve off the manifold to the brake pedal booster needs replaced?
Jim Isaacs
Harvest, AL
1988 Milano Verde
1979 Sprint Veloce
Old 03-15-2008, 05:57 PM
papajam's Avatar
papajam papajam is offline
I'd think that the check valve is the culprit too. Try plugging or squeezing off the vacuum hose to the booster. If the idle now stays the same with the brakes applied, 99% it's the check valve. The 1% is a bad booster but I'd think that you'd be able hear a hissing sound that pulses with engine speed.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 03-17-2008, 05:55 AM
La Voce's Avatar
AnsArias
Thanks, unplugged the hose at the booster end (it's sucking as it should), and confirmed no change in idle speed when the brake pedal is depressed. I drove the car with the vacuum line disconnected and plugged and oddly, I like the manual brakes better than the boosted. Yes, it takes a bit more pedal pressure, but it's not too bad, and the feel is significantly better. Anyway, looks like another $70 leaving my wallet for a new valve. Before I do that though, is there a way to be certain it is the valve and not the booster? There's no hissing or moaning noise when I step on the brakes when the line is connected, just the idle speed and smoothness change, which by the way, exhibits the same characteristics regardless of engine idle rpm- I increased it up to 2,500 rpm and with the hose reconnected, idle speed still falls down to barely running.
Jim Isaacs
Harvest, AL
1988 Milano Verde
1979 Sprint Veloce
Old 03-17-2008, 08:35 AM
papajam's Avatar
Originally Posted by La Voce View Post
...is there a way to be certain it is the valve and not the booster?
Yes. Two things can be done. One is to pull a vacuum on the booster with a vacuum pump (or your mouth if need be) and see if it holds a vacuum. The other is to remove and check the operation of the check valve. It should allow air (or vacuum) to pass in only one direction. If the check valve allows air to pass in both directions, you may want to try cleaning it before buying a new one. I've had good results cleaning them with an off the shelf spray carb cleaner.
