Old 03-12-2008, 02:44 AM
7/77GTV2545 7/77GTV2545 is offline
Question Building my supercharged 2l
I am currently in the process of supercharging my 77 gtv... i have three engines to play with... I am using the existing aircon bracket modified to support the sc12 toyota blower, plumbing this into a smallish intercooler infront of the radiator and into the origional air intake. i have got my hands on some turbo seal kits for my dellortos and am currently building two sets from NA models.
However actual turbo DHLA40 dellortos have a sealed atmosphere vent on the top but I have seen this on a turbo delta car with boost pressurised lines to these vents any ideas?
Does anyone know if it is possible to reshape the combustion chamber to avoid or reduce pinging? as I am going to do a head service anyway
These dellortos were used for turbo applications and therfore can be tuned to opperate with variable boost requirements.. does anyone have any ideas with regard to changing jetting? do i even need to?
Has anyone done this?
Old 03-12-2008, 04:19 AM
buzzed buzzed is offline
Hi,
I am also doing a supercharger conversion!
We should def swap ideas and theories.
Reshaping the combustion chamber - Not that I knw of, its really decided by the valve angle...the massive dome is not ideal as we know.
That said, there are many things that can be done to avoid detonation.
1. reduce comp ratio - drop in some twin spark NA pistons...they fit, and drop the ratio down to around 7.5:1
2. run rich mixtures - helps cool the charge
3. retard ignition suitably
4. run 98 octane - depending on your use , run shell vpower racing, its 100 octane
5. intercooler - you are running one, run a decent sized one, and ensure that you duct the airflow so that it has no where to go but through the cooler.
Do all of these things and detonation will be the least of your worries...it'll be the walking wet liners :-)
Benica's in Vic are the people to speak to about tuning the delloto carb, and you can be almost certain that they changed jetting in them...but that is a guess from me. If you ask them nicely they may give you some tips...otherwise, keep your eye out for an old turbo motor with the carbs on it.
email me at mbarrenger@optusnet.com.au if you want to chat more about your project....we can swap ideas>
cheers
Mike
Old 03-12-2008, 05:19 AM
alfahaka alfahaka is offline
You definitely need completely different jetting for boost (vs NA) *and* you need to match the jetting to the particular boost characteristics. I suspect the tune will be significantly different for the supercharger vs turbo (different, but maybe easier to get right due to more consistent boost - but I'm just speculating here). The problem area is the progression as boost comes up - the guy who did the last tune on mine described the jetting needed as "weird" - expect a bit of dyno time and make sure you have an improbable selection of emulsion tubes available....
All the turbo DHLAs I have seen have lines from the plenum (ie boost pressure) to the float chamber using a ported cover that replaces the standard vented cover. I'm pretty sure it is this way on Lotus Esprit's as well (its been a while since I've seen one though).
Darryl
'81 Autodelta Turbo Alfetta (perpetual project)
'91 75 Twinspark (not so daily driver)
'88 Jaguar XJ40 Sovereign (the wifes car/she that must be maintained)
Cannondale road bike (daily peddler)
Colnago road bike - old, Italian, steel, and no rust
