The early GTV6s (1981-1982) used ballast resistors with the original coil. The later cars and Milanos don't. If you don't have the original coil (likely you don't) then you don't need 'em. You should have a Bosch EI coil, or similarly rated coil, though, so make sure that's right at least.
Karl
[B]Have:[/B] 1969 1750 GTV under restoration
1969 1750 Berlina
1968 Giulia Sprint GTV (very rough, no motor)
[B]Had:[/B] 1982 GTV6 3.0 w/4.10 rear, Stebro (imported engine from UK in 2002) -- Rear-ended 8/2004.
1988 Milano Verde
[B]Non-Alfas:[/B]1984 Volvo 244
