Old 02-22-2008, 09:01 AM
Ennio Ennio is offline
Fixing gtv6 mirror
Hello, I have lots of trouble with my second hand Vitaloni 3133o mirror that I bought to a bber (the motor doesn´t work, the unit was welded on its base so couldn´t be turned and when sanding the metal cover, very bad rust was found).
Rust issues have been cared for by now and I think that when I paint the car I would probably buy a good used one that can be fixed. I had the electrci motor changed here, seems that BMWs use the same one, that what the guy told me.
I know have trouble with the welded base, the mirror could be turned in and was fixed at a very strange angle that made visibility very difficult. My mechanic unwelded the base, and was unable to find a good strong coil spring that holds the mirror in place. The mirror wobles a little bit and doesn´t hold its position as it should. I wanted to lknow if anyone knows of a spring that would work, or a way in which the mirror could hold its position and be able to move freely.
Ennio
1982 gtv2.0
