Old 02-16-2008, 09:48 AM
GTVMach1 GTVMach1 is offline
Lightbulb Size of socket for GTV6 spark plug
Hi,
I have tried a 16mm, 18mm and a 21mm socket for an 84 GTV6, none works.
Does anyone know what size plug and socket can be used on a GTV6?
I tried them also without the rubber insert (I thought some inserts were a little too long preventing the socket going into the plug). Didnt work.
3/8" was definitely too small.
Any idea what plugs could have been used by previous owner?
Old 02-16-2008, 10:51 AM
AlfaTango1's Avatar
AlfaTango1 AlfaTango1 is offline
but this one goes to 11..
13/16" or 21mm will work but it needs to be thin walled.
currently: 1984 GTV6 (Sabrina) 1992 164L (Jill) 1992 164S (Kelly) 1989 Spider Veloce (Julie)
Old 02-17-2008, 02:22 AM
gtv27's Avatar
gtv27 gtv27 is offline
there is a factory tool that came with the car (if you can find one) or as per above, buy the slimmest 21mm you can find, and if necessary attack it on a bench grinder.
Jason
GTV6 2.8 litre
Old 02-17-2008, 05:30 AM
Originally Posted by GTVMach1 View Post
Hi,
Normally you use a 13/16" thin walled spark plug socket with rubber insert unless somebody put in some different style plugs then maybe you need a 5/8" sparkplug socket.
If plugs are standard 13/16" and you can't get thin walled socket into spark plug well check with mirror and flashlight to be sure the rubber spark plug well gasket isn't blocking socket entry.
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 02-18-2008, 08:36 PM
GTVis4me's Avatar
GTVis4me GTVis4me is offline
Send a message via AIM to GTVis4me
I had to grind down a regular one last year cause I couldn't find a thin wall and needed it right away. It still works. If you can find a hardware store with a grinding wheel they'll do it. Mine did it for free.
84' GTV6
68 Spridget
Old 02-19-2008, 12:46 AM
sh0rtlife's Avatar
sh0rtlife sh0rtlife is offline
i recommend pulling the valvecovers and making sure that there alignment with the head is PERFECT..i used 3 fat sparkplug sockets as alignment pins...now i can actualy use a "normal" spark plug socket and dont need a thinwall any more...mind you i cant use any realy fat ones but im not forced with a realy thin wall one
[SIGPIC][/SIGPIC]
Old 02-21-2008, 05:02 PM
Smile
Thanks to all of you who replied. I'll grind down a 21mm socket
Old 02-21-2008, 06:15 PM
I doubt you will find a 21mm sparkplug socket in US but 13/16 are available. Here is link to Sears spark plug sockets: Sears.com
Virginia Beach, VA
Old 02-21-2008, 08:21 PM
karmat's Avatar
karmat karmat is offline
My new GTV6 has about the tightest fit of any V6 car I've seen. I had a thinwall plug socket that worked on the original 2.5L motor in my old car, the 3.0L I put in it, and the 3L in my Verde. But it wouldn't fit in this car, even with the valve covers lined up. I was getting ready to grind one down and someone said the Craftsman socket will fit. I thought, heck why not?
Perfect fit, with a tiny bit of play. I'd start there.
Karl
Have: 1969 1750 GTV under restoration
1969 1750 Berlina
1968 Giulia Sprint GTV (very rough, no motor)
Had: 1982 GTV6 3.0 w/4.10 rear, Stebro (imported engine from UK in 2002) -- Rear-ended 8/2004.
1988 Milano Verde
Non-Alfas:1984 Volvo 244
Old 02-26-2008, 06:12 PM
chasgtv6 chasgtv6 is offline
I use a 13/16 socket ('82 GTV6) stamped "EASCO USA" bought at a local Murray's auto parts store. No grinding needed, fits in hole as is
Old 02-26-2008, 06:41 PM
Alfar7's Avatar
Alfar7 Alfar7 is offline
Richard Jemison
Plugs and socket
Just convert to a 3/4 reach 5/8 hex plug and life is much simpler at plug changing time.
Richard Jemison
RJR Racing
http://scuderiagiallo.com
Old 02-27-2008, 02:20 PM
re. 3/4reach etc.........Brand?? heat range?? Thanks
