Old 01-25-2008, 02:45 PM
Autodelta V6 information
I have put the Autodelta instuctions for building a 200hp V6 back on my site at Performance Page . These are instructions from the real Autodelta, which was a performance division of Alfa Romeo, not to be confused with the UK based tuner that has latched onto the name.
Greg Gordon
Old 01-26-2008, 03:47 PM
shadowmilkman shadowmilkman is offline
love this.
thanks for adding this to the forum. great find
Old 01-26-2008, 04:28 PM
Gabor K. Gabor K. is offline
Have been in contact with you(G.G.) some years ago in order to correct some info. This time the camshaft numbers are correct Autodelta ones, but the timing is the bog standard road version. So that info should be removed to avoid confusion.
About the pistons I got the info that they were from Borgo and ratio being 11.8 : 1. Last year we got a genuine contemporary set of set of Group A pistons which were of forged type made by Mahle. CR was 12-12.5 so it had to be adjusted for street use. These are in present street use.
The GTV6 2.5 Gr.A spare parts catalog:
Old 01-27-2008, 07:17 AM
Hi Gabor,
Thanks for your help. I am sure you are correct. I am simply posting the info exactly as Autodelta published it for historical purposes, and to act as a general guideline. I did add notes regarding your comments.
Regarding the pistons, I am sure Autodelta used many different pistons in the 2.5, however in these documents they only listed these two. The Shankle 10.5:1s which are N.L.A. and the Autodelta pistons for which they give us a part number but no specs. I added a note that you think these were 11.8:1.
The camshaft information is incomplete at best, but that's the way Autodelta published it.
Greg
Old 01-27-2008, 07:56 AM
Alfar7's Avatar
Alfar7 Alfar7 is offline
Richard Jemison
Comments on Autodelta specs
George, would it be ok to comment on some of the specifications , Autodeltaand some of yours?
Thanks Rj
Richard Jemison
RJR Racing
http://scuderiagiallo.com
Old 01-27-2008, 07:59 AM
Richard, I don't know who George is, but I am sure we would all like to hear your comments on cams.
Old 01-27-2008, 08:05 AM
MALDI's Avatar
MALDI MALDI is offline
Gabor K., would you be willing to distribute the GTV6 2.5 Gr.A spare parts catalog?
Alternatively, I am sure AlfaGTV6.com ~ Home of the Alfa Romeo Transaxle would host it under the Techical page. That way you would not be bothered with emailing it out.
Old 01-27-2008, 08:29 AM
Alfar7's Avatar
Richard Jemison
Comments on GREG`S link
Greg,
Neither do I. One of the pleasures of brain injury....
I was in reality asking you. Your site is a wealth of information for all Alfa owners and I only have a couple of comments, cams, pistons/compression, suspension components.
Unlike another on the BB your post are most often right on, and you are welcome to use any comment of mine you find useful. I agree in general with most of your positions, but not all and suggest other ways to the same or better result.
From a time problem I might separate them as I am a pitiful typer and spellcheck is necessary always.
Maybe we should start another thread. George & RJ`s thread on 119 performance .
Rj
Richard Jemison
RJR Racing
Old 01-27-2008, 09:17 AM
Gabor, I agree with Maldi, it would be great if you could scan and post that catalog. A lot of historical information like that is really hard to find.
Richard, I appreciate the kind remarks. Feel free to post away in this thread. Your knowledge of cams for the Alfa V6 is probably unsurpassed in the U.S. I for one would like to know the specs for the cams Autodelta suggested for a 200hp 2.5. Just how much hotter were they than "S" cams? Do you have cams that would suit this need? If so I would like to include that info on my site.
Greg
Old 01-27-2008, 09:38 AM
Maldi: The spare parts listing is not so fun/informative as one would think. Mostly its a list of part numbers and prices without explanations and specifications. In some cases I took a telephone and asked about specifications and made a note. They were rather secretive about specs those days. If you still are interested in a copy, I could scan the lists. However the scans would probably be to big to publish here without resizing. Or I could send it to you by PM.
Greg G.: The timing of the cams, in your info, are definitively the standard road cams and I am sure the race cams had a lot more radical opening times. However in the beginning the lift was specified as not more than standard and timing free. At a later stage also the lift was free. Standard power output was 232HP/7900 rpm.
Old 01-28-2008, 12:05 PM
Grant's Avatar
Grant Grant is offline
Hey Greg, I like the new information that you have added. I think you could also suggest that the SZ spindle doesn't have to be purchased, as you can lengthen your own spindle.
The benefits of a higher roll center have been left out too. Did the SZ have the same location of the watts linkage in the rear?
1984 GTV-6 - 80K miles
Old 01-28-2008, 12:40 PM
I thought about that, but I am trying to keep the page limited to what a typical shop, or enthusiast can buy off the shelf and install.
Old 01-28-2008, 08:19 PM
Alfar7's Avatar
Richard Jemison
V6 cam issues.
I hope all that have read this thread has started at the beginning & read Greg`s link from his website and the other tuning info on the V6 which is very valuable to all of us. I hope I can provide a little insite on some cam info on these motors.
Before I get started, you will find on my website, (in the "How TO" section) if you scroll down far enough, you will find some info & comparisons of some Alfa V6 12V cam grinds. I will refer to those for lobe shapes & lifts to explain a bit on making these motors work as they should with different induction systems. But mainly EFI.
Questions about the cam timing of the cams speced by Autodelta might be best addressed after the basics on this specific motor`s cam needs are considered. Short duration/overlap does not mean weak cams.
These motors are difficult designs to build proper camshafts that work as the driver expects. As you know, everything has to happen from a cam timing event to make any power, and unlike the 4 cyl. Alfa`s we can`t change the lobe separation angles at will, to alter the engines breathing characteristics.
( lobe separation is a fuction of Lobe centers for the intake & exhaust for each cylinder. Add the two together & devide by 2. The result indicates the relative length of the power stroke & propensity for overlap. The same lobe design with LSAs of 114 will be low end biased (more torque) or if at 100 will be more effective at high RPM)
It all has to be designed into the cam by the builder before it is ground.
The cams can be tuned a minor amount (by advancing and retarding both cams a small amount, Just like you would a Chevrolet/Ford) to enhance the powerband towards more low end or high end performance. Alfa knew in it`s wisdom not to make the cam sprockets adjustable, otherwise most motors would have experienced bent valves from "improved timing".. We had to redesign the sprockets ourselves to make them adjustable for the race motors with big cams & cut down heads. Unfortunatly all the stock cams are biased to emission control design and not much comes from minor adjustments, although there is a good bit of "slop" in the drive units that allow a degree or two at the cam.
The 164"S" cam has a bit wider lobe separation angle (109.5 as opposed to the GTV6/Milano/164 cam`s 108). This is not bad, as the low end is enhanced by the cam timing (wider lobe separation angles) and the 1mm lift gives more intake charge. The intake lobe is basically the standard lobe expanded to give 1mm more lift and 7 degrees more duration at .050 lift. It is still not much lobe above .100 lift where duration means something. (where the valve is open & piston stroke is creating the best negative pressure)
The lift rate is a bit quicker than most of Alfa`s designs but not much, as quietness, long life (from material that isn`t that durable) and lack of maintaince for the Dealer`s, are the first considerations (& did I mention emissions?).
The "timing event numbers" published for the various stock cam fitments are based on published "off the seat" timing occurances.
Aftermarket cam builders in the USA use as a standard for "timing events", valve lift at .050 lift at "0" lash. (Not "off the seat" measurements.)
If you are "degreeing in" a set of cams, and have set lash at .015 you would note where the degree wheel is, at .035 lift)
Euro cam builders seem to have no standard, but but in general I find overall duration is given at .020(.5mm) and duration at .040(1mm lift). So comparing cams is really guesswork without full profile information.
Back to cam timing and the V6-12V. Except for the early 2.0 & 2.5 the motor has been fuel injected. The 3.0 built & sold in S.Africa was carbed with the same Delorto`s as the small motors. They look good, but nothing to drool over performance wise. As do the 4 cyl. Alfa`s the EFI alfas respond poorly to cams with much overlap. (spica too for that mater) as metering is based mainly on manifold air pressure which is severely disrupted by back pulses into the intake system caused by overlap. This happens with the same negative effect on carburetted vehicles at lower RPMs. But they were built before the "E" word controlled engine design.
To make a "hotter" street cam work on these motors, the amount of overlap has to be addressed first. This is a function of lobe design in the late ramp & early flank of the lobe. This is where deviation from the traditional designed Alfa lobes of the past, pays big dividends in terms of low end performance(torque) and emission compliance (we hope), yet can give amazing improvement in performance across the full RPM range, because of expanded duration in the middle & upper lobe flank & nose of both intake & exhaust..
As a "for instance" compare the 164 "S" and normal Milano/GTV6/164 to the RJR 28/744 cam profiled on the website. The LC`s on the website were those used, but lobe centers could be built engine specific as any of the cams can be. It is easy to see how opening & closing events do not exceed stock cam because of ramp rate. Yet large duration gains are made.
FYI the lift timing data for all of the intakes are pure lobe lift for all. The Exhaust duration is given for the Alfa stock cams at the lobe as well. The RJR 744 exhaust cam is given as "duration at valve" which is done to reference their flow capacity Exhaust lift & duration is a function of the 1.4 rocker arm ratio. For comparison the pure lift/duration profile for the 744 compared to the "S"/all exhaust is below:
lobe lift .273 (6.95mm) "S" Exh. lift .252
.010 252
.020 234 228
.040 212 210
.050 204 204
.080 186
.100 177 174
.200 107 96
.250 60 24
These are hot street cams that work with the stock system and don`t still play within the emission tolerances..
I will pick up tomorrow at this point and hopefully get into the issues of lobe design as to intake track and the problem that really was difficult to overcome which was cam lobe design for the exhaust side what limits the motor`s RPM range & solution, and what seems to work well, and what it takes to fit high lift cams in the heads as it is far more difficult than the 4 cyl.
Richard Jemison
RJR Racing
  #14 (permalink)
Old 01-29-2008, 05:14 AM
MALDI's Avatar
"I will pick up tomorrow at this point ..."
Good, 'cause it will take me that long to digest all this great info!
  #15 (permalink)
Old 01-29-2008, 07:08 AM
Richard, that's a serious amount of cam information. It sounds like you are one of the few people who fully understand camshaft specs. Somehow I was unaware that you actually make cams. That's good news and I will add that info to my performance page.
I think most of us want a street cam that will give us an increase in power, pass emissions and have a minimal loss of idle quality and fuel economy. By that I mean still idle under 1000rpm but with a slight increase in roughness, and a fuel economy loss of under 2mpg. Will your mildest cams do that? I suspect they will.
Greg
