Old 01-13-2008, 02:18 PM
sh0rtlife's Avatar
sh0rtlife sh0rtlife is offline
transaxle swap steps?
anyone got or have a link to the factory transaxle remove and replace steps?...ive done tranny swaps on countless cars both fwd and rwd but never done an alfa...tho i did assist on a porsche transaxle
looks fairly normal from my stand point..just dont want to make something take longer than required LOL
[SIGPIC][/SIGPIC]
Old 01-13-2008, 06:59 PM
5yearplan's Avatar
The factory one, but I replied to someone else's post earlier: Engine Removal Steps Needed...
[SIGPIC][/SIGPIC]
You should buy my stuff: http://www.alfabb.com/bb/forums/showthread.php?t=44309
Restore and Engine Conversion:http://www.alfabb.com/bb/forums/showthread.php?t=46024
Old 01-19-2008, 05:48 PM
Todd Todd is offline
To remove only the transaxle
Raise and support the car as high as possible
Remove clutch fluid by bleeding
Remove rear brake fluid by bleeding
Disconnect clutch and brake lines
Secure lines away and cover to prevent dirt from entering the lines
Disconnect half shafts and remove
Remove rear flex disk hardware.....but only this
Using a floor jack support the clutch end of the transaxle
Remove 6 each bolts 3 each side that connect the dedion cross member at the front of the triangle to the body
Lower the front of the transaxle a few inches and the rear flex disk will be much easier to remove...free the drive shaft from the clutch flange
Raise the transaxle back into position and re-install a few bolts
Using MUCH MUCH MUCH CARE postion and SECURE!!!!!!!!!! the transaxle to 2 each floor jacks one at the front and rear
Remove the bolts at the cross member, but do not lower yet
Remove the rear bolt
Lower the rear slightly and slowly always keeping an eye for problems, or something unsafe
Procede to alternate between lowering the front and back until she is free
THIS ASSY IS HEAVY...............BE CAREFUL
Husqvarna 2002 CR 250 motocross(made in italy)
Alfetta sedan 1977 modified
87 Milano Verde low miles
Old 01-19-2008, 06:30 PM
sh0rtlife's Avatar
well i got it out...and aperantly made s few good idea short cuts...
unbolted the clutch slave from the case
unbolted the calipers without bleeding
is one suposed to unbolt the shocks to allow the dedion to come down more?...was a PITA to twist and angle the transaxle to get it out of the short distance between the front mount and the back of the dedion...cant imagine doing it with a jack..i just layed under it and man handled it
[SIGPIC][/SIGPIC]
Old 01-19-2008, 11:26 PM
5yearplan's Avatar
yeah I would have taken the shocks out. It didn't take but 1 bolt to get them out.
[SIGPIC][/SIGPIC]
