If you are just replacing the thermostat, you will only need the top gasket, it is the three bolt round one with a notch, there are two others, another smaller round three bolt gasket with out the notch. Then there is the square 4 bolt gasket that goes on top of the water pump.
I am guessing you are getting the thermostat from IAP? If so they will know which gasket you will need and you will be re-using your housing, just a suggestion on this, but get the bleed bolt and washer also if you plan to bleed the system, I have had a few bleed bolts fail on me and it is frustrating to have to wait on one to show up. Another thing with the IAP GTV6/Milano Thermostat, make sure when you mount it in the housing that you have a good snug fit against the housing, the one I got did not mount flush and did not really work well, I took it apart and ground a little off the rod so the flange was flush with the housing, although not very tight, and it still takes too long to warm up, so I need to grind a little more off the rod and firm it up against the housing, but I need to order a third gasket...
