Old 11-21-2007, 06:55 PM
Biba69 Biba69 is offline
'75 Alfetta GT engine bay relay
Not sure if this is a bad thing to do or not, but also posted this in Electrical:
I foolishly removed this relay without noting which of the three wires went on the three spade connectors. Unfortunately I'm not even positive it is a relay (though pretty sure) or what its function is. Just always been there.
It does not show up in the two - '75 & '76 Alfetta - wiring diagrams I have. However, it is definitely factory installed/original. It is a Fiamm - made in Italy.
If you could look see if your Alfetta has one, I'd sure appreciate it if you'd identify which wires go where and hopefully also tell me what it is for.
On my Alfetta GT it is located across left (driver's side) of the alternator, near the voltage regulator.
The details are:
Wires:
Black
Red
Orange
Numbers for connectors:
4/87
3/85
1/30/51
Any info on this would be appreciated.
Biba
Old 11-26-2007, 03:14 PM
sfalfa's Avatar
sfalfa sfalfa is offline
Registered Loser
Biba - did you figure this out already?
Is it the relay on my old '76 sedan that's got the green wire coming out of it in this picture (above the alternator)??
BTW: weren't you asking about the alternator cooling hose on the Alfa digest? I found the one that used to be attached to this car if you still are looking for one.
___________
Jeff B.
'75 Alfetta Sedan (rosso)
'69 Lancia Fulvia Rallye 1,3 S (rosso)
'92 Ducati 900SS giallo
gone but not forgotten
'79 Alfetta Sprint Veloce(luci del bosco)
'77 Alfetta Sedan (nero)
'76 Alfetta Sedan (argento metallizzato)
'86 VW Scirocco 8v
'72 Honda CB500/4
Pics! http://www.flickr.com/photos/13463758@N04/?saved=1
North American Alfetta Sedan Registry (work in progress): http://alfanaticsf.googlepages.com/
Old 11-26-2007, 03:17 PM
sfalfa's Avatar
Registered Loser
Duh! Here's the picture...
___________
Jeff B.
'86 VW Scirocco 8v
'72 Honda CB500/4
Old 11-26-2007, 07:01 PM
Jeff B., thanks for replying. I also listed this same thread under the electrical section and Papajam replied it was the relay for the brake warning light. He also gave me which colors of wires went to which spade connections. I notice you don't have the relay on your Alfetta GT.
I was looking for the air duct for the much later Alfa alternators which have four retaining bolts rather than the three which the earlier ones have like yours. I appreciate the offer of your cooling hose, but I do have one for that air duct. I just thought the other type of duct might have a different hose. I've given up on finding a four bolt air duct. I'm guessing your Alfetta is a '78 or '79? I have that same alternator/A/C compressor now on my '75 Alfetta and found that the nearest hole on the forward panel is too small for an air duct hose.
Biba
Biba
Old 11-26-2007, 07:25 PM
sfalfa's Avatar
Registered Loser
Biba,
Glad to hear you got papajams help...
The silver Alfetta engine bay shown above is from my old '76 sedan that also had the Baer (sp?) dealer-installed A/C. I currently have a '79 GT that doesn't have the cooling bracket at all (it used to have the upgraded factory A/C installed but I took that out 8 or so years ago and can't remember if the cooling bracket was on that set-up or not). Anyhow - I somehow ended up coming across my old air-hose for one of them the other day and thought of you.
Anyhow - I haven't checked my GT for the relay in question, as I had that sedan engine pic handy and thought it may help...I'm guessing I have it or something like it, since all's well in the brake warning light section.
Cheers!
___________
Jeff B.
'86 VW Scirocco 8v
'72 Honda CB500/4
