#16 (permalink)
Old 09-02-2009, 05:37 PM
Alfisto Steve's Avatar
Originally Posted by alfasrule View Post
Come on Steve You think a nut & bolt or the position is gonna make a difference. I've owned 12+ 116's and changed my share of Donut's and never ever had a problem. I swear!!
Maybe I'm lucky I don't know! But I got to change a clutch so I'll do what you say cause you're advice is awesome!!!
It only really applies if you find multiple washers under nut or bolt heads not just one under each end of that bolt and nut. It makes a real difference on a middle yoke that is splined if you remove yoke from spline or on front spline and pinch bolt at engine flywheel.
I just mark both splined pieces with center punch and paint just to be sure.
I learned my lesson hard way on a Fiat 131 2-piece driveshaft years ago by not marking spline and yoke. What a nightmare to go back and rotate the yoke a spline at a time until vibration went away.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models - 91 164L "Black Beauty" and 91 Argento aka "Quik Silver" (daughter's) 164B w/AT 1QUIK AG
Resting 91 "Bianco" 164B 5-speed
Spring Revivial: 91 "Old Blue" 164L w/AT
Rescue projects: Organ Donor 91 Old Nero 164L
SOLD 91 Argento 164L w/AT aka "Quik Silver 2", 93 Rosso 164L 5-speed
