21 - 30 of 30 Posts
can someone confirm that the 75/milano automatics have an lsd? and is the lsd centre interchangable bettween v6 transaxles?
Brad - in Australia believe the answer is yes. At least that's my memory of a 75 Auto we had and the wild slides it was capable of!
Alister
This may be of some interest too...
engine rpm at 100kmh
A similar discussion with useful info...
Idealy wouldn't you want the 3.50 tranny over the 2.78 tranny, it you liked faster acceleration along with the 4.10 gears? Of course you would have to get a milano lsd for better traction. I see they all have the same final gear, so it depends on how much you like accelerating. So early GTV6 tranny with Milano lsd right? If you were tracking your car you would want the same setup so you can pull hard out of the corner as well, right?
Transaxle Ratios
No, you don't want the 3.50 ratio transaxle as the gear spacing is really far apart. You'll have a lot of RPM drop with each shift. Also you only use first gear for getting the car rolling from a stop.
I'm in the process of building a box that uses 1st and 2nd from a Milano and 3rd-5th from an Alfetta. The hard part is the 5th-reverse cluster but we have a couple of different ideas on how to over come that problem.
Don't even know if you need these 78/79 A/T Sedan
1st 2.48
2nd 1.48
3rd 1
rev 2.09
13/46
Not to many of these around !
I have a factory spec book
'75 thru '79 Sedan
116.33-116.29
116.34-116.35
1st 3.3
2nd 2
3rd 1.37
4th 1.04
5th .83
rev 2.62
10/41
116.58 116.15
gearbox with reduced D.P. gears
1st 3.307
2nd 1.956
3rd 1.345
4th 1.026
5th .833
rev 2.615
10/41
The section showing the Australian and Swedish 75s is wrong for Australia. Our 3litre cars had either the standard 3.55 LSD or the 3.73 LSD in the QV, or Potenziata, as they are called here. The only four cylinder cars we had were the 2.0 litre Twin Sparks with the 4.10 LSD box.
21 - 30 of 30 Posts
