#31 (permalink)
Old 02-19-2009, 09:19 PM
AlfaTango1's Avatar
I see you arr in Berkley. Is this going to be a street car or track car? With the SC it won't pass California emissions.
currently: 1984 GTV6 (Sabrina) 1992 164L (Jill) 1992 164S (Kelly) 1989 Spider Veloce (Julie)
  #32 (permalink)
Old 02-19-2009, 09:30 PM
Street. And way to burst my bubble. shi*.
  #33 (permalink)
Old 02-20-2009, 12:21 AM
Although the 24V V6 is based on the 12V one, I do not think it is possible to put the 24V heads on a 12V block. You would need to find a complete 24V engine. The 164 24V is the easiest because Alfa had less time to make changes and adapt it to being transverse and FWD. People have fitted later 24V motors but things get more complicated. There is loads of stuff about this on the GTV6 forum. People in South Africa have fitted the 3.2 from the 156/147 GTA as well as monster 3.7 versions of this engine. Money wise it depends where you are and what is available, it might be worth buying a built up engine from South Africa for example but then there is transport, customs etc and you still have to get it fitted. The 2.5 is a lovely engine, its just not one of the quickest things on the road anymore (25-30 years on!). Supercharger wise, I think its designed to come on and off in couple of hours for emissions tests! As far as actual emissions are concerned, it shouldn't affect them if the injection is set up right.
  #34 (permalink)
Old 02-20-2009, 05:26 AM
Also things to be taken into consideration, costwise, is that you cannot put a supercharger on an old engine without overhaul of the engine first! Depending on the general state of the engine one must calculate additional cost for this in the project. Changing parts not up to spec. could easily double the price of the project!
  #35 (permalink)
Old 02-20-2009, 06:27 AM
mjr mjr is offline
Well thats not a rule of thumb though is it. it purely depends on mileage. If the engine is relatively low mileage, 60k 70k, and its healthy, there is no reason at all you can't just bolt on the SC. remember we are talking 7-10psi for a reasonable 220-230hp on the 2.5, which a healthy motor is more than up to, with the stock rev limiter left in place.
  #36 (permalink)
Old 02-20-2009, 07:59 AM
AlfaTango1's Avatar
It would take more than a few days not hours the take the SC off and get the car to look and operate as it was set up by the factory just for smog. That's if you don't have an intercooler and water injection. True the actual emissions should not be affected but California doesn't care about that.
  #37 (permalink)
Old 02-20-2009, 09:00 AM
I have 75k, there might be a problem with my main engine seal, and the engine could use a bit of work, over all it's a really well taken care of car.
I'd like to shoot for 250, if I can get it. But if that would seriously compromise the reliability of my car, I would stick with 220-230. At the end of the day, I want something that can still act as a daily driver.
I like the idea of setting mine up like Greg has his set up. I'd like an MP62. If it could handle up to 14 lbs of boost, I could maybe set it at 10 or 11 (MAYBE 12), and I think I would be set.
At the end of the day, my biggest reservation is running the risk of ruining the reliability of a good machine. I think just hearing stories of the miles people have put on their cars with these and other kits, would calm my doubts. I also would love to see high mileage examples. If I know that I could be safe for the next 80k miles, I'd do it in a second, but I have yet to hear anything from anyone on the topic of reliability.
I posted a new thread under engine conversions, asking if anyone has used Greg's kit, or any other kit, for that matter, although I haven't received any responses.
  #38 (permalink)
Old 02-20-2009, 09:14 AM
I don't think I mentioned this, but in addition to the $3100 kit, what else would I need to buy?
I see water injection, a connecting rod kit, forced induction non interference pistons, and supercharger crankshaft pulleys. these all look like great items, but it would bump up the cost of my project by quite a bit.
I am confused as to what is actually necessary for the setup I want to run (MP62 @10-12 lb of boost). I know I say that I want a reliable machine, and I can only assume that buying the extra parts (and maybe more) would improve the reliability of my GTV6, but at the end of the day, I need to be realistic here as to what I set myself up for spending.
Any idiot can probably assume this, but I'm no mechanic. Thanks for bearing with me.
  #39 (permalink)
Old 02-20-2009, 09:18 AM
AlfaTango1's Avatar
For ease of use and reliability I'd go with a 3.0 from a 164L. They are easy to find and cheap and for the most part even the intake runners would pass at most smog stations. You could always use the regular GTV6 plenum. You would be amazed at what an extra 30 hp does to a 2800 lb car. If you could find an S engine great or you could spend some money on S cams or GTA cams and probably still make budget.
  #40 (permalink)
Old 02-20-2009, 09:20 AM
These engines are now 22-28 years now, so even they had no mileage O-ring and gasket change would be due. It would be at bit of a gambling just to install a kit relying on low mileage. Just for your info companies in germany doing turbo conversions would demand that the car had less than 60.000km(37.300mls)! to give any guarantee for the job, and that is for much newer cars than this one. 75.000 mls(120.000km) would be out of the question without overhaul and repacking the engine. Well, that depends on how much one likes to gamble.
  #41 (permalink)
Old 02-20-2009, 09:40 AM
Interesting take, alfatango, but I was planning to do the conversion (if it is supercharged) myself (with my dad - who knows his stuff and has the tools).
I see how I could make budget purchasing a good 164s engine, but I couldn't install it myself, and with the price of installation? Wouldn't I be in the poor-house? Are we disregarding the fact that it could need an overhaul, too, and the fact that it would be less powerful that the sc?
I'm mostly playing devil's advocate, but let me know what you think.
  #42 (permalink)
Old 02-20-2009, 09:54 AM
AlfaTango1's Avatar
An S or L engine is not a very complicated swap, now a 24V is. You can even run the original L Jet engine management system with no issues. My L has 149,000 on it and it pulls like a train, my S had about the same. There are many L's lying around that you could pick up in California with strong engines. The Alfa 3.0 is very robust. I still have to say this is the best way to go since the blower will get rejected the first time you go to get it smogged. Well you could always register it in a state that doesn't have these issues and take the chance that way
  #43 (permalink)
Old 02-20-2009, 10:32 AM
Are you telling me that the 164 S or L engines are not 24v? I didn't know that. I thought they were all 24v. I know they're great engines. My dad has a '95 164Q and it's a bullet. The truth is that registering the car is not TOO big of a worry for me. my main worry is just that because the 164 engine is transversely mounted, it will be a royal pain (and more $ than I have) to get into the gtv6. Do you know how much something like that costs? (engine + installation)
  #44 (permalink)
Old 02-20-2009, 10:38 AM
mjr mjr is offline
Do yourself a favour, an email greg or ring him at the shop, you will get a million opinions on this forum, So talk to greg and get the facts from the horses mouth, then you can make a well informed decision, as to whether you want to boost, or go the 3.0 non boosted route.
  #45 (permalink)
Old 02-20-2009, 11:11 AM
AlfaTango1's Avatar
Transverse or longitudinal it's still just an Alfa V6 with two heads on each side and a flywheel in back (or side in an fwd car). If you took the GTV6 or Milano intake plenum and swapped it with the 164 runners you could not tell the difference.
Tags
2.5, 3.0, bore, engine, gtv6
