Old 09-03-2008, 05:21 AM
bcal's Avatar
bcal bcal is offline
Alfetta reverse light switch
Hi, my reverse light switch has packed up, open circuit constantly.
There was another similar switch on the box which isn't used (don't know what was for) so I decided to swap it, however this switch seems to work in reverse (not reverse gear).
So how does the reverse light switch work? I take it that the switch's plunger is full extended when in forward gears and the contact is open and when reverse is selected the plunger is depressed and the contact is closed.
Are these switches still available?
Bye for now.....
Brett.
Old 09-13-2008, 09:43 AM
iachella's Avatar
iachella iachella is offline
I don't have an answer, but I'm curious about the operation too, for another reason: when I put it in reverse, if my radio is on, it goes to static. Is it grounding out? Where is it located too, at the gear lever, or back in the transmission?
Stefano
Concord, CA
iachella [at] gmail [dot] com
Old 09-13-2008, 04:17 PM
bcal's Avatar
It's on the gearbox. It is normally open and closes when in reverse. I have no idea how that would effect your radio, but hey, it is an Alfa.
BTW, I replaced my mechanical switch with a proximity switch which drives a relay. Seems to work well and best of all, no wear and tear.
Bye for now.....
Brett.
Old 09-14-2008, 02:43 AM
alfettagtv2000's Avatar
alfettagtv2000 alfettagtv2000 is offline
Membro Normale
The alternator light glows dimly on my car when the reverse lights come on.
1980 Alfetta GTV 2000
