mmm, difficult to tell if it doesnt do it under load, but I would be very surprised if you have managed to break the diff on a standard set up, they are tough as nails. if its only doing it under load it could still be a donut or gearbox rear/front mount.
When under load and it starts vibrating, dip the clutch and see if it goes away. if it does, then at least you know your issue is on the gearbox, diff or clutch assembly.
