GTV6 Won't Start
Good day!
In the classic been-there-done-that mode, I once spent a week trying to get my '82 GTV6 to start, and went crazy (-er?); I had another to borrow parts from, and really got carried away switching coil, distributor, ignition box etc. I even had my neighbor use another car to try to push start it by driving it around the block (2800 RPM in 2nd gear even)- nothing!!!!
The symptom was no spark, and I was really getting a bit testy, having exhausted (I thought) all options, and finally had the car towed to a shop. The first thing the (real) mechanic did was put a charger on the battery, since it was getting a bit low from all of my well-intended cranking. Imagine my astonishment when, after about 20 minutes of quick-charging, it began to fire, and finally started!
The moral of this story, and simply my own conclusion, is that the Bosch L-Jetronic ignition system has an absolute lower threshhold (I believe it is 12.5 volts- mine will not start at 12.4), under which the system will not energize. So, in addition to making certain you have a strong battery, you should also check and clean all cable ends, clamps, and particularly ground (earth) straps.
Hope this helps!
Jim Barrett
Huntington Beach, CA USA
_________________________________________
JB
Always Looking For Another
