trying to steer clear - Alfa Romeo Bulletin Board & Forums
Old 08-06-2004, 07:46 PM
Send a message via AIM to 81gtv6 Send a message via Yahoo to 81gtv6
Cool trying to steer clear of problems
oh sorry, i had to.
The front right tire has a little bit of play left and right, just barely wiggling. Is there supposted to be a bit of movement or should it be stiff and sensitive like the left side?
Thanx for your help agian boys!
- Jake
Old 08-07-2004, 01:41 AM
Alfisto Steve's Avatar
It should not have any play in it. If play is up and down check wheel bearings for proper geasing and preload and ball joints for wear.
If left and right movement as you call it check inner and outer tie rod ends for wear. Usually play comes from inner tie rod ends socket wearing.
These can be replaced and are available from IAP under listing for suspension parts as 29061 for R/H and 29062 for L/H. Get new rubber boots too.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models - 91 164L w/AT "Black Beauty I" ALFA4ME; 91 164S Black Beauty II ALFALFA
In 230,000 mile Rehab MY91 "Bianco" 164B 5-speed [My Originale], ALFISTO
Daughter's current ride: Her Granddads 2002 Ford Taurus
Current Car hauler and Parts chaser : 2000 Dodge Ram PU 5.2L V-8
Old 08-07-2004, 08:23 AM
Is there any way I can get my hands dirty and fix things myself, or replacement the only way?
Old 08-07-2004, 12:09 PM
I say get your hands dirty and replace worn inner tie rod end and rubber boot that goes over it.
Virginia Beach, VA
