air filter housing bolts - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 05-19-2017, 09:38 PM Thread Starter
Does anybody happen to know the diameter of the 3 bolts that fasten the lower pan of the air filter housing to the fender? I think they are 8mm x 1.0 thread pitch, but I may be wrong. I don't have Mike's car here to check, and I'm working on a design for a support mount for the AFM. He has the Greg Gordon intake system, not stock.
Thanks muchissimo....
alfaloco
Lexington, KY USA
alfaloco is offline
post #2 of 6 (permalink) Old 05-20-2017, 04:29 AM
sportiva's Avatar
M8 1.25
Glen
86 gtv6 RED,LOW,LOUD
x 74 alfa sud sedan SLOW AND FUN
x 76 alfetta sedan DOG
x 81 alfetta sedan HAD IT 24YRS.NOW DEAD
x 86 75 v6 2.5 KILLED BY A FORD ON THE SYDNEY HARBOR BRIDGE
sportiva is offline
post #3 of 6 (permalink) Old 05-20-2017, 07:27 AM Thread Starter
Super! Thanks mate! You even confirmed the pitch...
I want to soft mount the support bracket down to the existing holes in the fender, and take the weight of the AFM off the connecting hoses. I think the rubber mounts will give enough movement to allow for the revving of the motor. We'll see...
alfaloco
Lexington, KY USA
alfaloco is offline
post #4 of 6 (permalink) Old 05-24-2017, 10:47 AM
wutdhec's Avatar
I'm missing the floating nuts in the holes for the filter housing. Does anyone have a source for those?
Could I use cage nuts like this?: https://www.amazon.com/uxcell-1-25mm...ds=m8+cage+nut
Hector
'91 Spider Veloce
'85 GTV6
wutdhec is offline
post #5 of 6 (permalink) Old 05-24-2017, 11:00 AM Thread Starter
Sure, Hector... you can use that type as long as they will fit into the existing holes in the fender. Maybe you want to check a local Lowes or Home Depot hardware section, see if they have anything M8 x 1.25 that will fit. Easier to return if they don't fit, right?
alfaloco
Lexington, KY USA
alfaloco is offline
post #6 of 6 (permalink) Old 05-24-2017, 11:52 AM
wutdhec's Avatar
Thanks alfaloco....that would be wise since returns are a hassle.
Hector
'91 Spider Veloce
'85 GTV6
wutdhec is offline
Replace with
