Cam Shaft Identification - Alfa Romeo Bulletin Board & Forums
 4Likes
post #1 of 20 (permalink) Old 04-18-2017, 08:44 PM Thread Starter
wwhite's Avatar
I have 2 cam shafts, in one box, came as spare parts.
The car has a 2000cc SPICA engine in it.
Can anyone help identify them from the tag on the box?
How do I tell which one is for exhaust, and which one is for intake?
1968 1750 Berlina, 1973 2000 Berlina
1978 Alfa Romeo 116 Alfetta Sprint Veloce 2000 GTV/4, 1978 2000 Spider
wwhite is offline
post #2 of 20 (permalink) Old 04-18-2017, 09:41 PM
If your cams are in fact 4 cylinder Alfa cams there was no difference between the intake and exhaust cams on all production 1300/1600/1750/2000 models.
Jim Tyson is offline
post #3 of 20 (permalink) Old 04-18-2017, 10:55 PM
sbadaro's Avatar
I don't know but on my 'slightly' modded 2 litre ASP is marked on the intake cam and SCAB on the exhaust cam... no idea if stock cams are identical on intake and wxhaust but you may want to check the part number stamp on the cams themselves, as it makes a huge difference in determining valve gaps (45/50 on stock, 25/30 on my gta cams... learned the difference the hard and expensive way)
Sent from my GT-I9500 using Tapatalk
sbadaro is offline
post #4 of 20 (permalink) Old 04-19-2017, 08:49 AM
Richard Jemison
Alfar7's Avatar
cams
Check the end (butt) of the cam for marking.
However the distinct white reflection on the scab cam likely indicates a "closing ramp". if you can feel it with your finger that will confirm it.
Typically reground cams such as these do not have a closing ramp and lash is specified tighter (.008 - .014) than those with a closing ramp (.016-.018).
sbadaro likes this.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #5 of 20 (permalink) Old 04-19-2017, 10:18 AM Thread Starter
wwhite's Avatar
I was hoping someone could read the hand written Italian on the label.
I did not see any markings or casting numbers on the cams.
I'll take more pictures of the cams themselves, in a couple hours.
I suppose I could put the cam in a couple of v-blocks, and use a dial indicator, and measure exactly what they are?
sbadaro likes this.
wwhite is offline
post #6 of 20 (permalink) Old 04-19-2017, 11:06 AM
101/105guy's Avatar
Marks are 34-64-64-34 degrees.
wwhite likes this.
'64 Guilia Spider
'67 GTV
'68 Giulia Super
101/105guy is offline
post #7 of 20 (permalink) Old 04-19-2017, 11:13 AM Thread Starter
wwhite's Avatar
Thank you!
wwhite is offline
post #8 of 20 (permalink) Old 04-19-2017, 08:33 PM Thread Starter
wwhite's Avatar
OK, found the stamp, and it matches the "PROFILO", profile: 12N2
What does this profile translate to?
Good for street/road/track, or is it max power output at the high rpm range for full race?
Are these cams usable for daily aggressive driving with a SPICA engine?
More images:
wwhite is offline
post #9 of 20 (permalink) Old 04-20-2017, 01:08 AM
101/105guy's Avatar
Interesting......
I have a pair of 11N2 cams. 11 being the lift in mm.
12mm lift is a bunch unless clearances have been checked.
'64 Guilia Spider
'67 GTV
'68 Giulia Super
post #10 of 20 (permalink) Old 04-20-2017, 05:39 AM
Andrew's Avatar
SCAR is exhaust, isn't it? ASP something would be intake.
12mm seems a lot of lift on a street engine. Centerline's stock cam specs shows the highest stock cam lift as 10.1, on 10548 cam. 2 more mm is .080" roughly. That's a lot. You'd need to check piston/valve clearance, and make sure the lobes didn't hit the lifter bores.
Andrew
Andrew is offline
post #11 of 20 (permalink) Old 04-20-2017, 09:03 AM
Richard Jemison
Alfar7's Avatar
cams
No, both inadequate fuel delivery, and 12mm lifts require head modifications, springs, and short guides.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #12 of 20 (permalink) Old 04-20-2017, 10:05 AM
alfettapb's Avatar
wwhite...this might be relevant or might not be but "SCAR" was a dealership/race team in the Tuscany area of Italy that successfully campaigned its Alfetta GT track cars in the touring car series in Italy in the 1970s, which might suggest that the cams with that name are strictly race cams
sbadaro likes this.
alfettapb is offline
post #13 of 20 (permalink) Old 04-20-2017, 10:17 AM
alfettapb's Avatar
...also regarding the Italian translation since I speak Italian:
fase disctribuzione ...............cam timing
aspirazione ........................intake cam
inizio prima del pmi .............initial before top dead centre
fine dopo il pmi..................final after bottom dead centre
scarico.............................exhaust cam
gioco punterie ...................tappet clearances
post #14 of 20 (permalink) Old 04-20-2017, 10:18 AM
alfettapb's Avatar
... typo......meant to write inizio prima del pms
post #15 of 20 (permalink) Old 04-20-2017, 11:15 AM
101/105guy's Avatar
By the way....
these cams are not regrinds like the ones sbadaro shows.
New, machined from billets and heat treated, just like Formula 1 motors!
Will not work well with a stock Spica pump or with stock set up.
'64 Guilia Spider
'67 GTV
'68 Giulia Super
Replace with
