Need a Damaged GTV6 Clutch Boot---HELP !! !! - Alfa Romeo Bulletin Board & Forums
post #1 of 1 (permalink) Old 03-20-2017, 09:32 AM Thread Starter
Hi Gang,
We've found a manufacturer who will be recreating new rubber clutch boots for GTV6s. What's required next is to provide them with a used sample(s) of one that is too beat to use on a car, but marginally complete enough to use for measurements for a pattern.
The factory boots are thin and often ripped in places. So, less-than-perfect should work fine as a master. If you'd like to contribute to the cause of helping get new and improved boots on the shelf, that would be deluxe. I'm told they will likely have to cut a sample up a bit to get all the interior dimensions required. So, prob not realistic to expect it to be returned in one piece.
If you have an extra or two that you are willing to contribute, you can contact me directly. uncleskeeter2@netscape.net
Thanks in advance for any help you can offer. In return, I can alert you that new replacement boots are available again.
Peter
planetmojo2 is offline
