82'gtv6 yellow/red wire - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By chairmankaga
post #1 of 5 (permalink) Old 03-18-2017, 02:28 PM Thread Starter
the yellow red wire which gives ground from the ecu to the bi relay on my 82' gtv6 does not give ground.i can bridge a ground from the bi relay or from the ecu and everything works fine.i've tried different ecu's and different bi relays and alway get the same result.any suggestions?
cowfy is offline
post #2 of 5 (permalink) Old 03-18-2017, 04:18 PM
sportiva's Avatar
A break along the wire or the wire has detached from one of the connector pins. You could use a multimeter and do a continuity test or try bypassing the suspect wire and connect direct from ECU to dual relay................. or have you already done that
Cheers
Glen
86 gtv6 RED,LOW,LOUD
x 74 alfa sud sedan SLOW AND FUN
x 76 alfetta sedan DOG
x 81 alfetta sedan HAD IT 24YRS.NOW DEAD
x 86 75 v6 2.5 KILLED BY A FORD ON THE SYDNEY HARBOR BRIDGE
sportiva is online now
post #3 of 5 (permalink) Old 04-10-2017, 05:07 AM
Hi
i have the same problem on my 2.5 gtv 85 model. is it possible that the ECU is not grounded properly. my next step was to ad a extra ground wire to the ECU through the multi plug but im not sure about the pin outs in the plug. Do any one have those or a internal diagram of the ECU.
i tested the yellow and red wire and cant find any fault on it.
tanks
Mini Shop is offline
post #4 of 5 (permalink) Old 04-10-2017, 08:03 AM
Does this help?
alfajp likes this.
'82 GTV6
chairmankaga is offline
post #5 of 5 (permalink) Old 04-10-2017, 08:54 PM
Thanks I will check again tonight.
Replace with
