Gtv-6 wheels - Page 2 - Alfa Romeo Bulletin Board & Forums
 6Likes
post #16 of 16 (permalink) Old 03-20-2017, 10:17 AM
Mark_toro's Avatar
Tire rack had a couple that fit the Fiat 500X - 5 on 98 and acceptable ET. The hub bore is a bit small - you could probably grind/sand them by hand to make it fit. I made up a 1/4" spacer and use them as lug centric versus hub centric. 16X7.5 if I remember correctly.
I posted a thread on them when I mounted them up last fall. You can search on my name and find it. I mention tire sizing as well because that is important too. and they were $800 ish for the set including tires.
Mark
racingswim2006 likes this.
84 Spider - Long gone, but started the addiction; 85 GTV6 - Current project, Supercharged, Mega Squirt; 88 Verde - "Milo" It has a name, must be a keeper
Mark_toro is offline
Replace with
