Attached Images - Alfa Romeo Bulletin Board & Forums
 7Likes
post #1 of 50 (permalink) Old 04-13-2017, 06:40 AM Thread Starter
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
That's it....that is all I see.... "Attached Images" but no image shows up.
See post #3
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #2 of 50 (permalink) Old 04-13-2017, 09:23 AM
tubut's Avatar
That's usually a sign of a bandwidth limitation between your device and the server, either for technical reasons (capacity and/or congestion along the path, such as too many users on the same WiFi channel frequency) or contractual reasons (GB limit of your subscription plan: almost all wireless carriers and cable companies clamp down bandwidth when an allocated monthly limit is reached).
You may need to switch from a 2G or dial-up connection to something quicker.
-Ruedi
'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, now a restomod in Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).
tubut is offline
post #3 of 50 (permalink) Old 04-13-2017, 09:57 AM
Gubi's Avatar
Nope, it's happening to me as well. It's a bug.
The "Your Notifications" link at the top is also busted: it now just goes to the User CP page rather than showing a list of notifications.
1991 Spider
Gubi is offline
post #4 of 50 (permalink) Old 04-13-2017, 10:01 AM Thread Starter
ARwrench's Avatar
Yep here too...also the icons for "bold" " Image" "color" and all the rest are gone.
ARwrench is offline
post #5 of 50 (permalink) Old 04-14-2017, 12:01 PM Thread Starter
ARwrench's Avatar
Also no ones avatar is being show...
My " Your Notifications" keeps showing 1 but comes up with nothing
..had to type in the 'IMG' to post how I feel
ARwrench is offline
post #6 of 50 (permalink) Old 04-14-2017, 12:08 PM
Trained (ex)Professional
papajam's Avatar
Thread moved to the 'Support' forum.
papajam is offline
post #7 of 50 (permalink) Old 04-14-2017, 07:39 PM
Mikes4C1300's Avatar
Same deal here. No avatars or attached images.
Mike
'60 Giulietta spider, '67 GTV
Mikes4C1300 is offline
post #8 of 50 (permalink) Old 04-14-2017, 08:21 PM Thread Starter
ARwrench's Avatar
Mike
Thank you..Thought I was the only privileged one Sh!t...won't even let me post a smiley face
ARwrench is offline
post #9 of 50 (permalink) Old 04-14-2017, 09:53 PM
tubut's Avatar
OK, here are some hints for Tech Support: It appears the problem is with the responsive design. I can force the issue in my Chrome browser (on Win 10) by switching to "Responsive" in the Inspect mode (via Ctrl-Shift-i) and reloading the page, which rewrites the URL and pictures are not shown. The difference in the URL is most noticeable by the changed character sequence starting with "/#/" after the subforum title. Those users having problems may want to let Tech Support know which type of URL they see (with or without the "#").
Below are a couple of screenshots from post #2 of the superb "Vin's S4 Transmission Rebuild for Dummies" thread (obviously, those users having problems not seeing pictures won't see the screenshots, and the first URL will be rewritten as the second one):
This URL shows pictures:
Code:
http://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/573833-vins-s4-transmission-rebuild-dummies.html
Name:  2017-04-14 AlfaBB 1.jpg
This URL doesn't show pictures (note also how the URL inside the post gets shown differently):
Code:
http://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/#/topics/573833?page=1
Name:  2017-04-14 AlfaBB 2.jpg
-Ruedi
tubut is offline
post #10 of 50 (permalink) Old 04-14-2017, 10:29 PM
I purchased a donut compression tool from Alfa Romeo forty years ago. I have found out that donuts installed on transmissions never need to be compressed during removal. The only time you need to compress the donut is after you remove the steel strap and have to remove the donut. I do not think that I ever used my donut tool.
Alfaboutvegas likes this.
kuni123456 is offline
post #11 of 50 (permalink) Old 04-14-2017, 10:40 PM
tubut's Avatar
Ahem. This thread is about an AlfaBB problem where some users experience pictures not showing up. You may want to post your opinion about the donut tool in the thread I used to illustrate the problem.
-Ruedi
tubut is offline
post #12 of 50 (permalink) Old 04-15-2017, 06:02 AM Thread Starter
ARwrench's Avatar
ARwrench is offline
post #13 of 50 (permalink) Old 04-15-2017, 07:52 PM
Ruedi,
It's interesting you mentioned Chrome. I read the BB on an iPad and use the native Safari browser. That's where I've recently had the avatar and attached picture problems. After reading your post, I tried reading on Chrome and everything functions fine. So I guess the short answer is just use Chrome. Is the Safari angle worth looking into?
Mike
post #14 of 50 (permalink) Old 04-15-2017, 10:57 PM
tubut's Avatar
Yes, for Tech Support, this matters. Browser name and version are supplied to the server with every HTTP/HTTPS request. The server prepares the response accordingly. Since Safari is often used on small screens, most likely responsive design rules are invoked -- which seems to be where the problem occurs.
-Ruedi
tubut is offline
post #15 of 50 (permalink) Old 04-16-2017, 12:35 AM
Bored Member
jc96's Avatar
this is weird. I too, can not see avatars or attached images. I can't reply using "quick reply" but can using "reply". I'm going to try and post a pic on this reply. I'm using Firefox FWIW. ciao, chris
added, no pics cause attach images isn't available
Maintaining my tenuous strain on reality.
89 164 2l Twin Spark, 2011 Tonka Dump
Recently added: an 89 75 (Milano) 1.6 litre w/44K on the klok.
Past loves:
79 Alfetta GTV w/Spica, my 1st Alfa
An 88 Graduate. Not really love but interesting nonetheless.
A 68 BMW 1602 - man do I regret letting that one go!
79 Scirroco, ex plowed into an illegally parked house with it...
jc96 is online now
Replace with
