Go Back   Alfa Romeo Bulletin Board & Forums > General Forums > Alfa Romeo Videos
  #16 (permalink)
Old 05-07-2008, 05:44 PM
msiert's Avatar
msiert msiert is offline
Originally Posted by streetfame View Post
Out of respect for your thread Murray, I have deleted my posts. I just thought I would share what I have seen and what does work for me. All the best.
streetfame
Your post were fine? Everyone has their opinons and their was nothing wrong with yours.
Originally Posted by Grant View Post
Hey Murray, do you have any front end geometry work (alfaholics kit)? Do you have a panhard or similar on the back?
No panhard rod (really would like one someday) but I do have IAP sport springs, Koni Yellows, frame stiffner, neg. 2 deg camber with a competition alignment, poly bushings, a stock rear sway bar, a 29 mm front sway bar and the suspension has been balanced.
The car was so neutral at the track, when I spun it was do to down shifting going into the corner causing the rear tires to drag at the same time I was turning.
Murray
1991 Black Spider
The "Black Spider" project
Street Video
Track Video
  #17 (permalink)
Old 05-07-2008, 07:13 PM
Grant's Avatar
Grant Grant is offline
That's great then, sounds like you can't get much better than that as far as balance goes.
If you're still working on getting a grip on such a powerful car, you could mess around with the tire pressures to make the car understeer slightly, this could give you more confidence to attack the turns harder, which would give you a better lap time. A neutral car is just about the quickest way around a track though ( I think a car with a touch of oversteer is the quickest on most tracks, especially smaller, tighter ones.).
1984 GTV-6 - 80K miles
Articles
