Wanted gtv6/milano 2.5 cold start injector - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 1 Post By jett
  • 1 Post By Del
  • 1 Post By Del
post #1 of 15 (permalink) Old 03-20-2017, 07:24 PM Thread Starter
as the above.looking for a cold start injector.mine just lets fuel thru and doesnt close.
cowfy is offline
post #2 of 15 (permalink) Old 03-20-2017, 08:59 PM
I would buy one from Larry at Alfa Parts Exchange if Centerline Alfa does not sell a new one.
kuni123456 is offline
post #3 of 15 (permalink) Old 03-20-2017, 09:46 PM
Del
Or, you may be able to start the car without it. Just plug that fuel line? Richard2 can start his Milano without it hooked up, and I spect I could mine as well.
Del
Seattle
previously owned since 1964:
Del is online now
post #4 of 15 (permalink) Old 03-21-2017, 06:10 AM
ghnl's Avatar
Places like OK Injectors or Cruizin Performance can often resurrect an injector. They clean them with solvents & an ultrasonic bath.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
- fuel injector cleaning
ghnl is offline
post #5 of 15 (permalink) Old 03-21-2017, 06:52 AM
I`m sure I have a good used one if nothing else works out.
40usd plus shipping from Canada.
Let me know
jett is online now
post #6 of 15 (permalink) Old 03-21-2017, 07:13 AM
As Del said, mine starts fine most of the time without the CSI hooked up. The car came to me that way and it starts so well, I never bothered to reconnect it. If it's very cold out, below say 15F, or it hasn't run for a month or so, I may have to crank it a couple of times, but it has never failed to start.
Richard2 is offline
post #7 of 15 (permalink) Old 03-21-2017, 07:35 AM
110% true but the issue is that if it`s stuck open gas will keep on flowing thru
cowfy likes this.
jett is online now
post #8 of 15 (permalink) Old 03-21-2017, 10:01 AM Thread Starter
sure i plugged the line.you guys covered all the bases.firstly she start like a brand new car.really.the trouble is for about 4-5 minutes she goes from 4 -5 cyl's working till finally all 6 are banging right.then she runs 101%.i thought the initial enrichment from the cold start injector would take out that problem once and for all.i do have an ultra sound cleaning device.perhaps there's carbon buildup???. right now before i plugged it up i could blow with just breathing strength and it let my breath thru.i think i'll put it thru the ultra sound cleaner.there is a electro magnet and spring to release and close the fuel and not much more.
cowfy is offline
post #9 of 15 (permalink) Old 03-21-2017, 10:59 AM
Del
"the trouble is for about 4-5 minutes she goes from 4 -5 cyl's working till finally all 6 are banging right.then she runs 101%"
If the car starts with the CTI line unhooked and plugged, ie, no fuel, injector removed and hole plugged, then the above 4-5 cylinder situation is not caused by that injector, or lack of.
Which plugs are you using? Does sound like plugs clearing.
Our Milano, as well the 91S and 94LS, runs very well with the NGK Iridium plugs, although there are lower cost options. Do not try the Bosch Plus 4 plugs. Never had them work well in either our Milano or the 91S. They tended to foul. And as I've mentioned, probably ad nauseam, lol, I use a fuel system/injector cleaner now and then in all the Alfas. No injector problems.
I would also make sure the dist and rotor are absolutely clean, uncracked, and free of corrosion. Also, the side of dist wiring and plug are undamaged and clean. Our Milano's would eventually back off, sometimes make partial contact, and had to be wired tight to the dist.
cowfy likes this.
Del
Seattle
Del is online now
post #10 of 15 (permalink) Old 03-21-2017, 11:18 AM
Got one if you want it!
AlfasRule!
1972 Montreal (The Pumpkin)
1975 Alfetta Sedan
1975 Alfetta Coupe Race Car
1982 Spider
1984 GTV-6
1984 GTV-6 Verde (GiGi)
1987 Milano (Da NEW Winta Beata)
1987 Milano Verde(Da kREDden Mobile)
alfasrule is online now
post #11 of 15 (permalink) Old 03-22-2017, 01:09 AM Thread Starter
interesting.
yes, i'ved tried the 4 'trode bosch , and also found them to be troublesome.i'm running 2 'troders now, but i'll try those ngk tridums tho.is there a number on them?
cowfy is offline
post #12 of 15 (permalink) Old 03-22-2017, 01:21 AM Thread Starter
checked on ebay.there are ireiiums and lasar iridiums.any suggestions?
cowfy is offline
post #13 of 15 (permalink) Old 03-22-2017, 01:26 AM Thread Starter
now i see there are also ngk iridium lX.the three different types could just be d'old marketing ploy.which ones exactly do you use?
cowfy is offline
post #14 of 15 (permalink) Old 03-22-2017, 01:49 AM Thread Starter
4 NGK Iridium IX Spark Plugs OEM UPGRADE Longer Lasting More Power / Mileage; yes that's what they claim.lol.i wonder if they'll shine your shoes also?
cowfy is offline
post #15 of 15 (permalink) Old 03-22-2017, 11:12 AM
Del
I use the NGK BPR6EIX plugs in my Milano, and they so far have worked well for a long time. Car starts instantly, you turn the key and it's running, and runs fine thereafter. However, no, they don't shine your shoes, or pour you a drink. Just let you hear the great sounds of the engine, lol.
PartCat
cowfy likes this.
Del
Seattle
Del is online now
