For Sale Engines - 1300 to 2.5 L - 20 Plus Available - reducing inventory - Alfa Romeo Bulletin Board & Forums
post #1 of 10 (permalink) Old 10-02-2016, 05:41 PM Thread Starter
Selling 20 plus years of Race Prep and customer engine work.
Some race prepped blocks and cranks
Call or email direct - serious inquires - I prefer not to provide blog chatter..... Thanks
Chris 585 330 5456
Alfa Engines For Sale
1300 750
1315 44364 Block/Frt Cover / Liners/ Rods
Complete Head /Cams/caps/Valves Lashed
1315 013268 Block/crank /Cover Pistons/rods/liners/front cover/pulley/rear trans plate
1315 013488 Complete full short Block/ Crank & rods -.010
1600
00112 08315 Block with main caps with main caps/ Cover
00502 06473 Complete /block with main caps/front cover/pulley/WP/rear trans plate
00514 17964 Block with main caps with main caps- Drilled and tapped for #2/4 Main Brg Oiling. Tanked/cleaned
1750
0548 04555 Block with main caps
00551 02564 Block with main caps with main caps- tanked & cleaned
00551 01897 Block with main caps with main caps- Drilled and tapped for #2/4 Main Brg Oiling. Tanked/cleaned
0051 00554 Block with main caps
0051 06934 Block with main caps
00551 1898 Block with main caps
2.0 L
no number Block Block with main caps/cover
no number Block Block with main caps/front cover/crank
no number complete Spica motor - pan to Valve Cover - full Spica available
no number Block with main caps
Cranks 1300 Various states
1600 Cleaned / drilled & tapped for plugs
1750 Full race / drilled and tapped/re-nitrided
1750 Several in various states
2.0 L Several in various states
Heads everything from full race to cores
Oil pans Every combination - all early Veloce gone….
Rods Yes EVERY TYPE
Several Carrilo broken Sets
Liners Yes EVERY TYPE
2.5 L V 6 4 from complete to Blocks
Chris
585 330 5456
cdmad4494@aol.com
Chris D is offline
post #2 of 10 (permalink) Old 10-03-2016, 01:06 PM Thread Starter
Sold the full race 1600 - Serial # 00514 51422
Thanks Chris D.
Chris D is offline
post #3 of 10 (permalink) Old 10-04-2016, 03:07 PM Thread Starter
Pending Sale
Euro 1750 - 0548 04555
Chris D is offline
post #4 of 10 (permalink) Old 03-08-2017, 05:14 AM
pletchspider's Avatar
What do you still have left in 1750 blocks?
pletchspider is offline
post #5 of 10 (permalink) Old 03-08-2017, 05:57 AM Thread Starter
Sold a couple 1750's but a Have good stock blocks to the race prepared with aditional oiling to #2/4 mains.
Also a few stock heads and stock to prepped cranks.
If you running Webers I have a Euro 1750 front cover - without the privisions for the fuel pump belt that makes a nicer clean look
LOTS and LOTS of stuff.....
Call 585 330 5456
Chris D
00551 02564 Block with main capss- tanked & cleaned
00551 01897 Block with main caps- Drilled and tapped for #2/4 Main Brg Oiling. Tanked/cleaned -
$1000 with polished/prepped race crank
Chris D is offline
post #6 of 10 (permalink) Old 03-08-2017, 10:41 AM
pescara's Avatar
PM sent
pescara is offline
post #7 of 10 (permalink) Old 03-08-2017, 11:45 AM
Looking for a stock 1750 block with fuel pump front plate if possible?
post #8 of 10 (permalink) Old 03-08-2017, 04:57 PM
oldcanuck's Avatar
Do you have a good set of 1600 liners ?
Bob
1966 Duetto
1976 Spider Veloce
oldcanuck is offline
post #9 of 10 (permalink) Old 03-08-2017, 06:10 PM Thread Starter
Liners
Yes
CAll me Friday - I'll go through and sort out a set.
CALL ME.
585 330 5456
Chris D
Bob
Chris D is offline
post #10 of 10 (permalink) Old 03-11-2017, 05:23 AM Thread Starter
502/1750 Prepped Block SOLD
Sold the 502 1600 block and the prepped 1750 hardware as well as the two 1600 -105 race heads.
Still have WAY too many parts....
750 Block assembly and head still available.
Some 1315 blocks/heads/cranks still available.
Call with your needs.
Chris D
585 330 5456
Chris D is offline
Replace with
