Old 11-16-2009, 11:16 AM
Fuel Injector Cleaning and Flow Checking
I have started a small fuel injector shop. I am offering FREE flow checking for Alfa owners, and reasonably priced injector services.
If you are in doubt about your injector's condition, flow checking them is a great idea.
If your injectors need service, for less than the price of just one new injector I can replace the inline filter, pintle cap, all external seals, and ultrasonically clean all four or six of your injectors. I will flow check them at all pulse widths and RPM levels your Alfa will see, unlike most shops that only bother to flow check under one or two conditions. I am also providing a 12 month warranty against any sort of injector failure on the injectors I service.
Here is a set of 4 injectors, before and after service. You can see the injectors improved dramatically. It's amazing to me that this car actually ran before the injectors were serviced.
Greg,
Silicone Hose Kits (918)760-0668
The injector site will be OKINJECTORS.COM although both sites will be linked together.
Old 11-20-2009, 06:29 AM
kredden's Avatar
Greg,
I've got a set of your (I think stage II) injectors that Bill Simms bought from you back in 2004 which I've had sitting around for a couple years that I bought for my MegaSquirt project to put on an engine I was building with S-Pistons and aggressive street cams, CSC headers, etc. I finally got the engine finished, installed, and broken in so I'm back to getting it running on the MS.
The injectors look quite clean so I'm not expecting any issues there but would really like to know the exact flow rate at the standard fuel pressure so I can set up the MS correctly. I'd like to take advantage of your offer here to flow test them so I can get that info, and also verify that they are indeed in good working condition before I go to the trouble on installing them.
Kevin
86 Spider Veloce
87 Verde
Milano registry custodian(www.alfamilano.com)
Old 11-20-2009, 07:59 AM
Hi Kevin,
That sounds great. My offer to flow check them for free still stands, especially for an older set of injectors that I supplied at some point. They only catch, is that the stuff I do for free does not go directly to the front of the line (i.e. no 24 hour turnaround) so make sure to allow a few days for me to do it.
Greg,
hiperformancestore.com
Old 11-20-2009, 10:46 AM
kredden's Avatar
Thanks, I understand completely about not being at the front of the line. I'll try to get them in the mail tomorrow to the address on the OKINJECTORS site.
Kevin
86 Spider Veloce
87 Verde
Old 11-20-2009, 03:30 PM
Grant's Avatar
Hey Greg, I would love to send you (4) high impedance injectors. I would like to purchase a level II or level III service. What email should I talk to you about it with?
1984 GTV-6 - 80K miles
Old 11-21-2009, 08:15 AM
Hi Grant,
You can send it to either of the emails on our hiperformancestore.com website, or call (918)760-0668 during normal Central time hours.
Update! We are going to add a charge if I have to take the old hoses off the injectors. So for the Free service you have to send me an injector with no hoses or seals on it. I will get the okinjectors.com site up dated and operational soon.
From what I have seen so far, you are going to want the level 3 service. So far every injector has seen gains by replacing the inlet filter.
Greg
Old 11-21-2009, 10:46 AM
kredden's Avatar
That's what I figured so I pulled them all off before I sent them this morning!
Kevin
86 Spider Veloce
87 Verde
