Lifting the 4C - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By kevinl
post #1 of 9 (permalink) Old 12-28-2016, 08:19 PM Thread Starter
Lifting the 4C
I found a sheet metal screw in my tire yesterday and pulled it out. It did not cause a leak that I know of yet, head was worn but not off. So the real question is how to lift her. I saw no references in the manual for lifting points or how to get a wheel off the ground. I want to lift her to check the tires for more screws but I have no jack low enough. Anyone tried to lift their car? I am thinking a air bag lift unless someone points me to a low jack suggestion and/or lifting points which just may lead me back to not having a low profile jack.
Still enjoying the ride, I read the last couple of threads. Mine had 1300k miles on her when purchased and the service manager never drove it until I picked it up. Radio/heat/AC is adequate its not a million dollar exotic just something I wanted and waited for. Wife just needs to put radio back to radio mode since I do not have a "Smart Phone" and she does not have the courage to back it into the garage.
Joe
_______
Joe, 85 and 79 Spiders
joeonship is offline
post #2 of 9 (permalink) Old 12-28-2016, 08:58 PM
VabeneGTV's Avatar
Check out 4Cforums.com, lots written about this, there. Do a search. Fran
VabeneGTV is offline
post #3 of 9 (permalink) Old 12-29-2016, 01:33 AM
kevinl's Avatar
I bought this jack for my 4C,I have not used it yet, but it is well built.
http://www.calcarcover.com/product/2..._Aluminum_Jack
Good luck
4Canada likes this.
1992 Spider Veloce (sold)
kevinl is offline
post #4 of 9 (permalink) Old 12-29-2016, 03:34 PM
This.
Here's one thread for you:
Lifting the 4C - Alfa Romeo 4C Forums
Sorry to divert you from this board, but this really answers your question better than it will likely be here.
Glad the tire didn't go flat on you.
4Canada is offline
post #5 of 9 (permalink) Old 12-29-2016, 08:47 PM Thread Starter
Now I am confused I cannot get an answer here so I have to log on to different site which does not let me view anything unless I have 10 or more posts. Someone please explain and ..if the answer is in my owners manual please let me know where.
As I see it the linked it the 4c forum site is not the same as this one, looks the same with the ADs popping up and the login in the same spot. Again can someone explain? I did not find any information to jack points in several of the threads.
Joe
_______
post #6 of 9 (permalink) Old 12-30-2016, 12:58 AM
Vsix's Avatar
Lifting the Alfa 4C
look that, Im not then takin any responsibility if thats correct or not...be careful
-Antti: --ex Alfas:155 2.0 8V '92,155 2.0 16V '96,156 V6 '98,156 V6 '02
http://carpix.1g.fi/kuvat/carpix/
Vsix is offline
post #7 of 9 (permalink) Old 12-30-2016, 04:26 AM
kevinl's Avatar
Lifting the 4C
This should help, it's in the owners manual. It's available downloadable for your phone using a google search.
Lifting points.
This should help when you go to put your tire back on.
kevinl is offline
post #8 of 9 (permalink) Old 12-30-2016, 07:18 AM
Sorry, joeonship, didn't realize the settings over there would interfere with your browsing.
As kevinl's owner's manual excerpt shows, the lift points are well aft (owing to the engine location), and well under the car.
You have just about 4-1/2" of clearance from floor to these locations (slightly more with the non-race suspension). Post #10 on the link I shared also shows this, but perhaps you need to be a member to view that. Again, I apologize (and I'm a moderator over there - I should probably have known that but I didn't).
The front lift points are simply reinforced sections of the carbon tub. They are identified by a small CF square (mine has red paint on it, but that could be a dealer thing). The aft ones are the connection between the rear sub-frame and the bottom of the tub - small exposed aluminum brackets exposed from the belly pan of the car. You'll ideally have these on a hockey puck instead of directly on a metal jacking surface.
The most popular lift from the link I showed you is the Ranger Quickjack 3500 or 5000 if you want higherr capacity for other vehicles.
From what others say over there, it fits with car on the floor.
I have an EZ Carlift, which I love. But you do need to run the car onto a small ramp or planks in order to slide it under the 4C. This is also a somewhat more expensive tool than the Ranger and needs different cross-members depending on the size of car you are working on, but it is American designed and made, and I do like it for a number of cars.
Both devices lift the entire car. There are suggestions not to lift one corner only. Not sure what harm it would do, and I know people who have done so. With the stiffness of the chassis, and the proximity of the lift points to the centre of the car, I can see you actually raising two or almost three wheels in trying to lift only one. There are some low-profile floor jacks which are low and long enough to fit. Most don't. And Sector111 makes an adapter which allows you to use one of these to access both rear lift locations at once (so you raise the back two wheels together). This is great for tires and brakes. Sucks for doing exhaust work because the apparatus is right in your way.
Hope this helps, and makes up for the bum steer I gave you before.
4Canada is offline
post #9 of 9 (permalink) Old 12-31-2016, 05:39 AM Thread Starter
Thanks for the more detailed info. I looked at my pictures when it was on my lift(drive on style). I see some blocks there and will have to get a low profile jack. My 79 is currently on the lift for brake caliper rebuild.
I will also look into the other forum as well.
Joe
_______
