Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > 1900, 2000 & 2600 (1950-1968)
Old 03-27-2008, 05:05 AM
caralio caralio is offline
valve clearance
Hi gents,
Do you know where to order valve clearances for 2600 engines? I live in Sweden .
Regards,
Lionel
Old 03-27-2008, 11:10 AM
tubut's Avatar
tubut tubut is offline
Page 6 of Pub. #912 "Technical Characteristics and Principal Inspection Specifications" provides the following information:
Ruedi
'63 2600 Touring Spider (apart)
'65 2600 SZ (resto project)
Old 03-27-2008, 12:53 PM
Yes,
Based on that information, I am out of dimension for four of them on the exhaust only.
Rereading my thread, I realise I have been inaccurate : I am looking for valve clearance adjusting pads (forgot the last 2 words, sorry).
Haeckner in Germany in selling a complete set of pads, but I only need 4 !
BR,
Lionel
Old 03-27-2008, 01:51 PM
tubut's Avatar
Although the parts catalog lists shims of specific dimensions, I'm not aware of anybody selling them individually (Afra.it may be the best chance).
It is my understanding that Alfa Romeo sold sets of valve shims to dealers, who would exchange the shims on a customer's car for shims with the correct thickness and put the used ones back in the set. The underlying assumption of the valve shim exchange seems to be that on average, the pluses and minuses of all changes will amount to zero. One could even argue that used valve shims are better because the material becomes denser with use.
In other words, the valve shims were not considered a consumable item that needed to be replaced with new ones. New valve shims were only necessary when old ones were damaged or lost.
If you can't find them, have some made (on a lathe) to your required specs in high-quality steel and make sure they are hardened.
Ruedi
Old 03-29-2008, 12:25 PM
mudshark's Avatar
mudshark mudshark is offline
Hello Lionel,
I changed out my valves for 9mm and have about 20 "old" shims still. If you let me know which sizes you need I can check if I have these.
George
Old 03-30-2008, 03:03 AM
Hi George,
That would be great.
Here are the thicknesses :
1.800
1.725
1.875
1.650
Based on the shop manual, the increment between each caps is 0.025 mm, so those values should be available, I hope you have them !
Why did you change to 9mm valves ? what are the main benefits ?
BR,
Lionel
Old 03-30-2008, 11:48 AM
mudshark's Avatar
Hi Lionel,
I can get you the 1.8 and 1.875, the rest I have are thicker but you could grind them. Let' discuss off line, email me pls georgew@hetnet.nl
rgds,
George
Old 04-17-2008, 10:44 PM
Lock Holmes Lock Holmes is offline
George, I like the idea of smaller valve stems. What valves did you use and what modifications were necessary to make them fit? Regards, Lock
Old 04-18-2008, 12:29 AM
mudshark's Avatar
Lock,
A machine shop in Holland did the work, they used Comp + super alloy valves by Ferrea, to the dimensions of the current twin spark engines. So not 9 as I said earlier but 8mm. The rest was all made to fit, including seats for lead-free petrol (this is europe..). It runs very smoothly and I can adjust with easy to get shims
Old 04-29-2008, 04:30 AM
Superleggera's Avatar
Superleggera Superleggera is offline
Lionel "Ventilshims" in your sizes can be ordered by Alfa Rosso in Göteborg tel 031 402510
mvh
Björn
Trelleborg
1952 1900 C Sprint 1959 Giulietta TI (Class winner Rally Monte Carlo 1960)1967 Giulia Super 1970 GT 1300 Junior 2008 159 TI SW
Old 04-30-2008, 09:09 AM
Hi Björn,
Good to know, it will be useful for next time and I guess it is a good address to know.
Thanks to Georges, I have been able to put everything back to the correct thickness.
Now , the engine is running smoothly, and I miss only a few thing to be ready to have the car on the road again , I can't wait, I have been working on it for the last 2 years !
I hope to be ready for Tjöloholm, will you go ?
Lionel
Old 04-30-2008, 09:58 PM
180OUT 180OUT is offline
RE: 2600's
Why don't you post some photos of your 2600 when you get the chance? There aren't many photos of 2600's here.
'70, 1750GTV, 2nd series
Old 05-02-2008, 05:01 AM
Lionel I hope to go to Tjolöholm but I´m not yet sure if I can make it.
rgds
Björn
  #14 (permalink)
Old 05-15-2008, 12:10 PM
Yes,
Sorry for late answer, but I was busy working on the car ! I am done with a lot of things, it's running pretty well now and I just passed the inspection, so I will post pictures when ready pretty soon.
Lionel
