Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > 1900, 2000 & 2600 (1950-1968)
Old 01-11-2008, 01:58 PM
paulvv paulvv is offline
2600 lug bolts/nuts help needed
Hello,
I am in the process of a 65 2600 spyder restoration(all wheel disc brake)...... 3 of the left rear wheel lug bolts spin. I suspect that previous owner did not realize that these are RH threads..and overtightened. The lug nuts do not tighten properly, and the threads are damageg on the lug bolts/nuts.
I would like to replace all 5 lug bolts, and nuts. Any sources? Can these be replaced on the hub in situ? Or does the hub have to come off and the bolts pressed out/in?
Thanks in advance.
Paul
65 Alfa 2600 Spyder
Old 01-12-2008, 05:12 PM
benicia 2600 benicia 2600 is offline
lug nuts for alfa 2600
Hello Paul
I jus did a wire wheel conversion on my 2600 alfa spider. I have perfect lug nuts and lug bolts available. Where are you located? I am in northern california.
Best regards
Herve
Old 01-12-2008, 06:58 PM
Thank you
Hello Herve,
Thanks for your reply. I would be most interested in at least one wheel's worth of lug/bolts for the driver's side, and perhaps some for the passenger side. Please email at vasquezpv@yahoo.com with your email address, pricing, etc. Looking for other 2600 parts as the restoration proceeds.......Thanks in advance.
Best Regards,
Paul
65 Alfa 2600 Spyder.
Old 01-13-2008, 12:09 AM
Hello Paul
Regards
Herve
Old 01-18-2008, 12:17 AM
AlfaJoe AlfaJoe is offline
Hello Herve,
I know this is a little off topic, but I wonder if after your wire wheel conversion you might also have a spare set of hubcaps. I have a '64 2600 spider, and one of its hubcaps is warped and just won't stay on. Though I only need the one hubcap, I wouldn't mind a set of four so as to have some back-ups. I'm pretty sure the caps I have are the type that originally came standard on this model, but I'd be happy to e-mail you a photo if that would help.
Thanks very much,
Joe
Old 01-18-2008, 04:32 AM
D&SW D&SW is offline
interested in what you did for a wire wheel conversion.
did you do Borrani's?
or Dayton (or other???)
thanks
David
74 GTV
64 2600 Spider
Old 01-18-2008, 09:24 AM
[quote=AlfaJoe;474699]Hello Herve,
Thanks very much,
Joe
I traded my hubcaps a while back
However I know that rich at alfeta motors has a few extras. If interested contact him at 707 6458154
Regards
Herve
Old 01-18-2008, 09:27 AM
[quote=D&SW;474729]interested in what you did for a wire wheel conversion.
thanks
David
Hello David
I did the borrani wire wheels conversion(with 16 inche wheels, to be abble to put wider tires) Even using 16 inche wire wheels with modern tires the tire is slightly shorter(1/2 inche)
Regards
Herve
Old 01-22-2008, 12:05 AM
Hi Herve,
Thanks for the tip about Rich at Alfeta motors for those hubcaps. I'll give him a call.
Best regards,
Joe
