2000T new project - Page 8 - Alfa Romeo Bulletin Board & Forums
 5Likes
post #106 of 225 (permalink) Old 09-29-2016, 10:41 AM Thread Starter
Hello !
As I want this car to be in a perfect condition I have scheduled to change almost all the screw, nuts and washers.
When I have disassemble the car I have measured all the screw, nuts and washers. I have stored all the data into an xls files and then I have order all the elements.
"Bid" screw are black, "small" one and nuts / washers are stainless steel.
Yesterday I receive the 98 references representing 765 items = 10,8 kg :
Name:  IMG_1619 copie.jpg
Name:  IMG_1616 copie.jpg
Xls file is available for everyone, but I have to translate into english.
PS70 is offline
post #107 of 225 (permalink) Old 09-29-2016, 12:58 PM
tubut's Avatar
Serge, I looked through your spreadsheet quickly, and would like to comment as follows:
For my 2600 Spider, I just did quite a bit of research into the fasteners attaching the upper and lower A-arms and for attaching the plate that holds the front suspension springs to the lower A-arms. This was triggered by the fact that the threads on several of these bolts were stripped to the point of being dangerous (and an Alfa technical bulletin advising the need for mandatory field upgrades as described below). I could not find any exact replacements for the Alfa parts because of:
(a) the dimensions (e.g. M8x1x42mm for the upper A-arm and M10x1x42mm for the lower A-arm) are not standard length and therefore not readily available (45 mm seems to be the closest standard size),
(b) the bolts are not marked with modern strength classification (i.e. no standard-compliant class or grade marking),
(c) none of the suspension fasteners are listed in the Alfa parts interchange list for standardized parts, and
(d) for the 2600, there was a technical bulletin advising repair shops that the nuts and bolts of the upper A-Arms need to be upgraded to higher strength -- for which they provided only an Alfa parts number. I'm not sure if this TSB applies to 102 cars as well (chances are that the larger 2600 engine and higher speed of 106 cars created much higher lateral forces on the front suspension, which led to bolt stretching Alfa described). Given that the front suspensions of 1900, 2000, and 2600 cars are almost identical, I think it might be a good idea to upgrade the fasteners for the upper A-arms on all of these models.
The closest (and probably safest) components I could get for my front suspension was Class 12.9 hardware (bolts, nuts, washers), but such hardware is not available with 1 mm "extra fine" thread pattern (specifically, no M8x1 or M10x1 Class 12.9 bolts or nuts -- the highest grade for such hardware was 10.9). Class 12.9 seem to be only available in standard thread (1.25 mm for M8 and 1.5 mm for M10) because of the higher pressure and torque values. I ended up buying Class 12.9 with standard thread. I surmise (but I'm not sure) that the difference between standard thread, fine thread and extra fine thread is a trade-off between shear strength (fine-threaded bolts seem to have a thicker cores and therefore higher shear strength than standard threaded bolts) and the axial stretching forces and torque that can be applied to the threads (standard threads can withstand higher forces because they have more contact surface area).
Sourcing Palnuts was an adventure in itself (there is one manufacturer in Italy that makes Palnuts for extra fine threads -- the supply situation for standard thread is much better). For the spring plate, I chose not to use the split lock washer under the nut, as shown in the parts catalog, but to torque it dry to Class 12.9 specs and use a Palnut instead for securing the nut from turning loose.
Like you, I had to buy boxes or bags of 100 pieces each -- even though I needed only 8 for my car. When I'm sure I'm done (I installed the front suspension this weekend and need to double check), I will make my surplus fasteners available to other owners.
With respect to your spreadsheet, including the Alfa Romeo parts numbers for the components (and maybe even what table they came from) would allow much better identification and comparison with what solutions are available.
-Ruedi
'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, now a restomod in Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).
tubut is offline
post #108 of 225 (permalink) Old 09-29-2016, 01:54 PM Thread Starter
Hello Ruedi,
Thank you for your answer.
I'm not sure my English level allow me to understand everything perfectly. But I assume I catch main ideas.
For the fixation of the A arm I have bought 12.9 class with a length of 40 (instead of 42 mm) and with 1mm "extra fine" thread pattern, diameter 8 and 10. I assume the 2 mm missing won't be an issue, but I may be wrong.
For the spring, 55 length with 1mm "extra fine" thread pattern, diameter 10. Conform to original.
You are right, for the nuts there is not classification. If you find classified nuts I'll be happy to know where or to buy you some parts.
I any case, I have consider that a new screw class 12.9 and a moderne new nut is much more beefier (strong) than a 55 years old screw and nuts that have been screwed and unscrewed several time and partly affected by corrosion.
I need some time, but I'll mention all AR parts number in front of each component.
PS70 is offline
post #109 of 225 (permalink) Old 09-29-2016, 02:03 PM Thread Starter
As we are discussing about screw, anyone could give me the size of the screw that secure the 2600 front caliper ?
PS70 is offline
post #110 of 225 (permalink) Old 09-29-2016, 06:14 PM
tubut's Avatar
Serge, I could only find class 10.9 nuts for M8 and M10 extra fine threads. A general notion of engineering safety seems to be that the nut should be equal or higher grade (stronger) than the bolt (never lower class), as failures of the bolts (stretching, bending, breaking) and bolt threads (stripping) are easier to detect than failures of the nuts (cracking, stripped threads). This safety precaution was the main reason why I chose to go with standard threads on class 12.9 bolts and nuts rather than a combination of class 12.9 bolts with class 10.9 nuts.
As for the front caliper bolts, I'm pretty sure they are shoulder bolts (shaft thicker than actual thread) -- but I'll need to check next time I'm in the garage.
-Ruedi
tubut is offline
post #111 of 225 (permalink) Old 10-01-2016, 04:19 AM Thread Starter
Thank you Ruedi for your answer and clarification. If you have 8 and 10 nuts available I would be interested.
Regarding the caliper the diameter seams to be 11 mm in 1.25. Hard to find ...
Yesterday I receive the new bumper.
The rear one is adapted to the width of the car.
The quality is irreproachable :
Name:  IMG_1628 copie.jpg
Name:  IMG_1631 copie.jpg
Name:  IMG_1633 copie.jpg
Serge
PS70 is offline
post #112 of 225 (permalink) Old 10-03-2016, 01:23 PM Thread Starter
Hello !
In order to improve the behavior in time and guidance, I plan to machine polyurethane silent bloc for the rear wheels.
Superpro is selling 30 cm bars that can be machined.
http://www.superpro.com.au/
Someone has experience in this area?
Serge.
PS70 is offline
post #113 of 225 (permalink) Old 10-03-2016, 02:41 PM
Redmerlin's Avatar
Serge
These silent bloc units may be availble form Superflex or similar I have a pair but no idea where they came from. They look the same as these at a silly price from Mr Fiat
Alfa Romeo 2000 2600 Polyurethane Trailing Arm Bushing Kit - 2000 2600 Spider - Alfa Romeo - Italian Cars
While having my car repaired at a long term alfa specialist in London . I asked how best to improve the track of the rear axle.
I was advised as follows
1. Don' fit two polyurethane bushes, this will make the suspension too sharp . Fit one poly and one std rubber.
2. Add a turnbuckle in each rear tie bar so the rear axle can be aligned the same as the tracking adjustment on the front wheels. Apparently the rear axle on the 2000/2600 was bolted in but never aligned.
good luck
Ian
Redmerlin is offline
post #114 of 225 (permalink) Old 10-03-2016, 02:49 PM
Redmerlin's Avatar
post #115 of 225 (permalink) Old 10-03-2016, 10:38 PM
tubut's Avatar
Serge, here are the dimensions from one of my bolts. I was not able to confirm the M12 x 1.5 mm fine thread as I have no thread gauge for measuring this specific thread -- so I suggest you first check this dimension in the axle hub with a threaded bolt of that dimension.
If you cannot find a shoulder bolt that fits (which probably will be difficult with the mixed imperial/metric dimensions), you may need to get a partially threaded 1/2 inch hex cap screw, reduce the diameter for the thread and cut it t length on a lathe, then thread it yourself.
Name:  P1040085 (cropped + 700 wide).jpg
-Ruedi
tubut is offline
post #116 of 225 (permalink) Old 10-06-2016, 10:51 AM Thread Starter
Thank you very much,
Sorry for my late answer, I was on business trip.
Ian, perfect !
Ruedi, thank you very much.
The thread seams to be M11x1.25.
The quality of the female thread is very bad (lot of corrosion). I propose to machine it to M12X1.25.
Other thing, the hole on the caliper is diameter 11mm. It is not and Alfa caliper, it is a Jaguar ...
So I'll buy a screw of 45 of length 12X1.25 and I will also machine the caliper to 12.
Hope it is clear...
PS70 is offline
post #117 of 225 (permalink) Old 10-06-2016, 03:07 PM
tubut's Avatar
I confirmed the thread is M12 x 1.5 mm (not 1.25 mm). Volvo 1800 with single circuit brakes were very similar to Alfa. You may want to check if caliper mounting bolt #668905 (see this page) fits. Check also the caliper lock tab #669012 in case you don't have it.
-Ruedi
tubut is offline
post #118 of 225 (permalink) Old 10-07-2016, 01:24 PM Thread Starter
Hello Ruedi,
Thank you for these information.
I don't know if I have different caliper older than you but believe me, I tried to screw a M12x150, that do no fit ... Too big.
Name:  IMG_1696 copie.jpg
PS70 is offline
post #119 of 225 (permalink) Old 10-11-2016, 02:28 PM Thread Starter
Hi,
I receive the Dynamo discover by Don.
I dismount it completely and it is perfect.
But ... There is somme difference with the model I have.
The pulley, the tending system.
Which is the good one ?
Name:  IMG_1711 copie.jpg
Name:  IMG_1746 copie.jpg
PS70 is offline
post #120 of 225 (permalink) Old 10-12-2016, 06:27 AM
Push hard and live
DPeterson3's Avatar
The one on the left looks more like mine. However, there may have been more than one version. Does it fit?
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
Replace with
