2000T new project - Page 6 - Alfa Romeo Bulletin Board & Forums
 4Likes
post #76 of 182 (permalink) Old 08-21-2016, 08:35 AM
Push hard and live
DPeterson3's Avatar
By the way, the "floating tappet" is unique to the 102, and perhaps the 1900. I do not know where to obtain new ones, but have read of a couple of companies that might fabricate them to order. They would not need to be changed to accommodate 9mm stems. You would replace them as a function of their condition, or if you were to install new or different cam shafts.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is online now
post #77 of 182 (permalink) Old 08-21-2016, 02:52 PM Thread Starter
OK Don, good !
The floating tappet are available at OKP (Retro Rosso for the french market).
Today I open the gear box to see how it is inside (I had a lot of trouble with the 2600 gear box) :
Very dirty but everything looks good (all the teeth are here).
Name:  IMG_1026 copie.jpg
Concerning the 2nd : The wolf teeth (I don't know what is the english name, I'm talking about the small teeth in front of the speed gear) look a little bit damaged. That could be the sign that the synchronizing ring is a little bit worm.
How can I know that the synchronizing ring should be change ?
Serge
PS70 is offline
post #78 of 182 (permalink) Old 08-21-2016, 07:19 PM
Push hard and live
DPeterson3's Avatar
That looks very new, or at least fresh. I'm not really a gearbox guy, but most of the synchros I've seen used up showed little to no grooves on one or both sides.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #79 of 182 (permalink) Old 08-22-2016, 12:35 AM
AlfistiSA's Avatar
Serge those little "wolf" teeth should be slightly pointed with a slight angle on the top, they look 'tres bon' in your picture, similarly the grooved syncro ring also looks 'tres bon'
Those are the early syncro rings and will require the correct Dentax oil (huile) without the EP additives of modern oils.
The trick is to remove the 2nd gear synchroniser ring and swap it with 5th gear after turning 5th around as only 1 side ever works on the 5th gear synchroniser ring, also do the 1st gear fix, which makes a difference when selecting 1st from stop. --> First Gear Fix
Salut
Greig
AlfistiSA is offline
post #80 of 182 (permalink) Old 08-22-2016, 01:35 AM Thread Starter
Thank you to both of you for your answer !
Greig,
The trick to use the 5th gear synchroniser ring to replace the 2nd one is very clever !
But to access to the 2nd gear ring, you must disassemble the ball bearing on the right. To do so, you are obliged to push with a press on the axe while fixing the external cage of the ball bearing. The effort goes through the ball and might damage them no ?
The ball bearings of this gear box look all good. I still have to wash and degrease them to be sure, but they seams OK.
So, if my second gear synchroniser ring don't need to be change I prefer to leave it and not take the risk to damage the ball bearing.
Do you thing I can leave such synchroniser ring ?
I read your link regarding the first gear : amazing => Thank you. I will check that on an old 2600 gear box and probably use its parts to upgrade the 2000 gear box.
Thanks a lot.
Serge
PS70 is offline
post #81 of 182 (permalink) Old 08-22-2016, 01:44 AM
AlfistiSA's Avatar
The bearings are not that tight on the shaft &I have never damaged one pulling them off, also my pullers are for bearings and shaped like [( )] to go around the shafts and support the bearing as much as possible.
I also heat the gears with a hand held propane torch to expand them and they either come off or go on really easily when warm & expanded
Salut
Greig
post #82 of 182 (permalink) Old 08-22-2016, 02:18 AM Thread Starter
Hi Greig,
Than you. I have the [()] tool you mention.
So from your point of view, the 2nd synchroniser ring should be changed.
PS70 is offline
post #83 of 182 (permalink) Old 08-23-2016, 09:12 PM
AlfistiSA's Avatar
Hi Serge
It depends on what the syncro ring looks like, the dog teeth (wolf teeth) are also very important to the syncro action.
It may be that your gearbox was rebuilt already, it would be better to have someone who knows these boxes check it out for you in person.
** the new Goetze syncro rings sold by Classic Alfa etc are for the newer type synchromesh (EP oil containing Molybdenum) & the parts are NOT interchangeable with the older type (Dentax or NON-EP oil) that you have here **
Salut
Greig
post #84 of 182 (permalink) Old 08-24-2016, 04:47 AM Thread Starter
Hi Greig,
Thank you for your answer.
I will follow your advice and show the parts to several friends I have here in France. Pictures are sometime misleading ...
Anyway, I think I will change the synchro ring. It is not so much work and I can't imagine I discover any problem with the gear box when I will have renewed everything and start the engine.
Concerning the Goetze syncro rings, I have been told that you can use them in our 102 & 106 gear box if you change also the Stop & Locating segments and the stop strip by type 105 parts.
Yesterday I have open the steering box:
Bad news
Name:  IMG_1062 copie.jpg
Name:  IMG_1065 copie.jpg
Name:  IMG_1068 copie.jpg
I will order the new parts to CHS in Brazil
Name:  K26-SR - Alfa Romeo 2600 RHD-2.jpg
Serge
PS70 is offline
post #85 of 182 (permalink) Old 08-24-2016, 05:11 AM
Alex's Avatar
Serge,
When the molybdenum synchro rings were introduced, Alfa published a technical document listing all the parts that needed to be changed to allow an early 105 gearbox to use the moly rings, for 'metallurgical reasons'. BB member Papajam posted a scan of this a few years ago. The list is more extensive than just the segments and band.
I also discovered in the Competition Reference Handbook that early dog rings are 6.6mm deep, moly type are 7mm. That might be the most critical difference of all. See here for more.
Alex.
to all parts I have advertised on the BB so far. Plenty more! Just ask.
Alex is offline
post #86 of 182 (permalink) Old 08-24-2016, 09:13 AM
tubut's Avatar
FYI, you probably mean CHS is in Argentina (see here), not Brazil.
It would be great to learn if they now have kits for 2600 steering boxes (which I believe were upgraded from 2000 steering boxes as discussed in separate threads).
-Ruedi
'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, now being restored in Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).
tubut is offline
post #87 of 182 (permalink) Old 08-26-2016, 10:41 AM Thread Starter
Your are right Ruedi. I don't know why I was thinking CHS was a Brazilian company.
The advantage of this kit is that the gear worm is installed on its shaft. This installation is very very hard to do ...
The kit is also much more complete than the one send buy usual europen suppliers.
As soon as I will receive it I will inform you about its quality.
PS70 is offline
post #88 of 182 (permalink) Old 08-26-2016, 11:17 AM
Push hard and live
DPeterson3's Avatar
I've got three steering boxes sitting on my bench for years awaiting overhaul. I've got some good looking gear sets, but would like to try one or more of these new ones. As I've noted before, I've got at least three, and I think four, different gear-set configurations. I do not know if the gear sets can be interchanged into every box, but I am certain that some gears will fit some shafts, but not other shafts. Removing and replacing the gear onto the shaft is not really difficult with a hydraulic press. The picture of the kit above makes it appear necessary to at least install the gear onto the input shaft.
I'm still wishing someone would advise the process for driving out the pin for the sector gear. How is it held in place? I'd rather hear from experience before I start experimenting. Also, which part number kit should we use? There are several variations I've seen discussed, but no clear summary.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #89 of 182 (permalink) Old 08-26-2016, 11:49 AM Thread Starter
Here is the picture corresponding to the kit I will order :
Name:  AR2000 -1960 Steering repair kit.jpg
PS70 is offline
post #90 of 182 (permalink) Old 08-26-2016, 01:01 PM
tubut's Avatar
Rather than taking Serge's thread too deep into a particular topic, may I suggest that we continue the discussion about steering box particulars in this steering box thread, where Ian posted some info he received from CHS here and Don pointed out some differences and suggested we should compile a list of "box numbers"here?
Also, I hope we can get Jay to chime in there with his knowledge and experience of dis- and re-assembling what must be dozens of steering boxes.
-Ruedi
tubut is offline
