2000T new project - Page 5 - Alfa Romeo Bulletin Board & Forums
 4Likes
post #61 of 182 (permalink) Old 08-16-2016, 11:11 AM Thread Starter
I have just found pictures of a 2000 Touring distribuated by La Régie Nationale des Usines Renault - a "French" car.
https://www.flickr.com/photos/125618...39506493/page1
You will appreciate the wonderful "Nivoclair" reservoir.
PS70 is offline
post #62 of 182 (permalink) Old 08-16-2016, 01:38 PM
tubut's Avatar
Originally Posted by Seattle Dan View Post
While I've found the glass bottle and rubber components, like you, from a local Citroen parts dealer, he has been unable to locate a new aluminum cap, which is the one part I could use.
Dan, this supplier for French car parts in Germany seems to have the caps as a stock item (pictures below are from their web site). The item description in their catalog says:
"Cap for a brake fluid reservoir from glass. Thread about 44mm. Suitable for Citroen 11CV, 2CV, HY, Panhard, Peugeot 203, 403, 404."
The thread diameter of "about 44mm" would translate to about 1-3/4 inches, which probably would have to be verified before ordering.
-Ruedi
'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, now being restored in Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).
tubut is offline
post #63 of 182 (permalink) Old 08-16-2016, 02:43 PM
tubut's Avatar
Great, Serge (and thanks to Baboon for posting them)! Here are a couple of pictures cropped so that they highlight the reservoir.
Name:  23818815461_2d833de624_k (cropped 700 wide).jpg
Name:  23533389999_a5f53b7334_k (cropped 700 wide).jpg
-Ruedi
tubut is offline
post #64 of 182 (permalink) Old 08-16-2016, 02:47 PM
Hi All,
On my 1900CCS original delivered to Belgium there was also this glass bowl on the brake system .
rgds Franco
franco-veloce is offline
post #65 of 182 (permalink) Old 08-16-2016, 05:58 PM
IRONBLOCK's Avatar
Originally Posted by franco-veloce View Post
On my 1900CCS original delivered to Belgium there was also this glass bowl on the brake system.
It must make it easy to see when you are low on fluid or need to change your brake fluid.
Mark
IRONBLOCK is online now
post #66 of 182 (permalink) Old 08-18-2016, 02:00 PM Thread Starter
Hi,
Yesterday I received the complementary parts for the brake system :
Master Vac,
4 way connection,
Vacuum valve for the intake manifold,
Vacuum hose.
Name:  IMG_0902 copie.jpg
Name:  IMG_0905 copie.jpg
The master vac is the one installed on Austin Healey 3000 : It is much more reliable than the 2600 Girling which vacuum piston is sometime a nightmare.
All parts purchase to English car spare parts dealers which prices are unbeatable.
Concerning the engine :
Do you know where I can find new pistons and new valve ?
Serge
PS70 is offline
post #67 of 182 (permalink) Old 08-18-2016, 05:14 PM
Push hard and live
DPeterson3's Avatar
For a 2000, all the regular sources should have internal engine parts. OKP and Classic Alfa are my favorites.
I've had Pistons made by both JE and Venolia. The last two engines I built I used JE pistons organized By "Top End Performance" in Southern California. They also renewed my connecting rods. We reduced the diameter of the wrist pins (and hole in the piston) to reduce the oscillating mass.
If you are going to overhaul your cylinder head, I recommend you find a shop that can convert your valves to a 9mm stem instead of the original 10. This will make it much easier to adjust the valve clearances.
Good luck
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is online now
post #68 of 182 (permalink) Old 08-19-2016, 02:44 AM Thread Starter
Thank you Don for your answer,
9mm valve is a very very good idea but I need more clarification please :
If I change the diameter of the valve from 10 to 9, I'll have to change the valve guides too.
On the 2000, the external diameter of the valve guide is around 15 mm.
The car equipped with 9 mm valve (such as 105 type) have valve guide of 14 mm.
So how shall I proceed ? Where can I find valve guide of 15 with internal diameter of 9 ?
I assume that the floating tappet should be change too ?
Serge.
PS70 is offline
post #69 of 182 (permalink) Old 08-19-2016, 08:25 AM
Push hard and live
DPeterson3's Avatar
Serge,
There are two approaches that I can imagine to achieve 9mm stem.
The valves in the FNM 2300 have a 10mm stem, but 9mm tip. They will fit the standard guide. I believe the spring retainers and keepers are different as well. Not sure where you would obtain these parts, but they certainly exist somewhere.
A good machine shop could also find valves with 9mm stems that have the correct heads and lengths. It is no big deal to locate, or fabricate, guides that would fit the head and stem. Also, retainers, keepers, and springs can be specified to suit.
The key is a top quality shop with a history of vintage and/or racing work.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #70 of 182 (permalink) Old 08-20-2016, 05:16 AM Thread Starter
OK, thank you Don for your answer
I finalize the dismounting of the car.
There are still some details :
I have a switch, on the left side of the wheel, under the dashboard.
I cannot dismount this part : Is this part original ? If yes, how can I dismount it (the button appears stuck to the axis). If it is not original, I will destroy the button.
PS70 is offline
post #71 of 182 (permalink) Old 08-20-2016, 07:38 AM
Push hard and live
DPeterson3's Avatar
This is not original. Another French oddity?
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #72 of 182 (permalink) Old 08-20-2016, 11:57 AM
tubut's Avatar
Given the diameter of the wires (and the fact that there seem to be three wires), could this be a substitute for the original light switch, which seems to be missing in the picture you posted earlier (only 2 knobs visible on the left side of the steering column)?
-Ruedi
tubut is offline
post #73 of 182 (permalink) Old 08-21-2016, 02:02 AM Thread Starter
Thank you for your answer.
Ruedi, I have all the witch :
Name:  WP_20160430_020 copie.jpg
I'm sure it is not a froggy oddity
It is may be due to that :
PS70 is offline
post #74 of 182 (permalink) Old 08-21-2016, 08:16 AM
tubut's Avatar
Now, that's something rare. I hope you'll keep it!
-Ruedi
tubut is offline
post #75 of 182 (permalink) Old 08-21-2016, 08:24 AM Thread Starter
Of course !!!!
PS70 is offline
