2000T new project - Page 11 - Alfa Romeo Bulletin Board & Forums
 4Likes
post #151 of 182 (permalink) Old 12-22-2016, 09:41 AM Thread Starter
Great Ian !
Thank you very much.
PS70 is offline
post #152 of 182 (permalink) Old 12-28-2016, 11:10 AM Thread Starter
Here it is :
With the finger, it is impossible to engage the rear :
Name:  IMG_3257 copie.jpg
If you push on the level you can engage the rear gear :
Name:  IMG_3256 copie.jpg
PS70 is offline
post #153 of 182 (permalink) Old 12-31-2016, 03:56 AM Thread Starter
I everybody,
I'm now working on the propeller shaft :
Name:  IMG_3337 copie.jpg
Unfortunately, the universal joint is damage :
Name:  IMG_3345 copie.jpg
Such part is very expensive if we buy it to the specialized distributors (OKP for exemple). But I'm sure it is a standard components. Does anyone have a source for such part ?
"Bon bout d'an"
PS70 is offline
post #154 of 182 (permalink) Old 12-31-2016, 08:58 AM
Hi,
you are missing the protecting cover-shields of the bearing and also the end axle bolt must be rounded.
FYI :
I have no cheaper source for the the universal joint
rgds Franco
And for ALL
******* HAPPY NEW YEAR ********
franco-veloce is offline
post #155 of 182 (permalink) Old 01-02-2017, 06:22 AM Thread Starter
Happy new year to everybody !!!
Thank you for your answer Franco. You are right, but the part you mentionned were missing ... I'll see if I can find the protecting cover-shields.
I can't understand what you mean by the end axle bolt must be rounded: Isn't it the case ?
I have worked on the rear axle:
I have settled the differential using Plastigauge.
New bearing - New sealing - Looks good :
PS70 is offline
post #156 of 182 (permalink) Old 01-02-2017, 07:13 AM
rounded end
see picture
post #157 of 182 (permalink) Old 01-03-2017, 01:29 AM Thread Starter
Thank you very much Franco, everything is clear. I have ordered a pair of protecting cover-shields from a 105 type (same bearing). I hope the parts are the same. Still missing the spring.
I wanted to order all components to renew the FISPA fuel filter to Alfa Stop, no answer since more than one month. Do you know where to find components for such FISPA (Filter, spring, joins) ?
PS70 is offline
post #158 of 182 (permalink) Old 01-04-2017, 12:04 PM Thread Starter
Rear axle is finalized :
Name:  IMG_3416 copie.jpg
PS70 is offline
post #159 of 182 (permalink) Old 01-04-2017, 01:33 PM Thread Starter
alfa123ca and DPeterson3 like this.
PS70 is offline
post #160 of 182 (permalink) Old 01-05-2017, 08:51 PM
FISPA rebuild kit
Serge - just picking up on your question about FISPA Fuel filter parts I thought I'd warn you that I also tried to get a rebuild kit for the FRB-11 from AlfaStop. When the kit arrived, the diaphragm didn't fit the spring housing and the pin was too short and too wide to operate the regulator valve. I couldn't get any response from AlfaStop to report the issue and so went to Then & Now Automotive in the US who also advertise an FRB-11 rebuild kit. When their kit arrived it was exactly the same as the AlfaStop kit. I contacted Mike at Then and Now and they kindly modified the diaphragm to fit. Maybe there are different variants of the FRB-11? It would be interesting to know if other owners have had the same issue.
Here's some pictures to show what I mean.
Richard
86 GTV6 (RHD), 60 Touring 2000 Spider and 59 Giulietta spider race car
RichardM is offline
post #161 of 182 (permalink) Old 01-05-2017, 09:56 PM
tubut's Avatar
AlfaStop lists two different FRB-11 kits (with pin and without pin) but they seem to have the same picture, so it's unclear what the difference really is. And yes, it appears Tony has been hard to reach for months now. I hope everything is OK with him -- it would be bad if we lost another supplier. Gordon Raymond, who posted this info concerning the FRB-11 pressure regulator screw, recommends Viton gaskets from Geoff Ohland @ PARTSOURCE in Camden Maine (they don't have an online catalog).
Rebuilding the FRB-11 is almost not worth the trouble given that Filter King 67mm Fuel Filter Regulator with glass bowl can be bought relatively inexpensive
(e.g. see eBay item 152012823945). I wonder how much of the innards could be transplanted.
-Ruedi
'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, now being restored in Austria)
Maintainer of a private 2600 SZ register (not the one in the Netherlands).
tubut is offline
post #162 of 182 (permalink) Old 02-05-2017, 12:36 AM Thread Starter
Hello everybody,
A long time I didn't gave some news :
Concerning the Fispa, I have produced a new membrane based on a CitroŽn Traction one - Thank you to everybody for the advises regarding existing kits:
Name:  IMG_3959 copie.jpg
Name:  IMG_3961 copie.jpg
Name:  IMG_3966 copie.jpg
Name:  IMG_3973 copie.jpg
Name:  IMG_3979 copie.jpg
PS70 is offline
post #163 of 182 (permalink) Old 02-05-2017, 12:48 AM Thread Starter
Body work is going well, major things are repaired, finishing step can start :
Name:  IMG_3887 copie.jpg
Name:  IMG_4032 copie.jpg
Name:  IMG_4044 copie.jpg
Name:  IMG_4036 copie.jpg
Name:  IMG_4037 copie.jpg
PS70 is offline
post #164 of 182 (permalink) Old 02-05-2017, 12:56 AM Thread Starter
Rear axle is finished, with new shoes :
Name:  IMG_3793 copie.jpg
Name:  IMG_3794 copie.jpg
Name:  IMG_3802 copie.jpg
Name:  IMG_3798 copie.jpg
PS70 is offline
post #165 of 182 (permalink) Old 02-05-2017, 01:03 AM Thread Starter
Concerning the main axle and its center bearing, I have bought deflector for a 105 type.
Name:  IMG_4057 copie.jpg
As I had no spring to maintained the front deflector, I replace them by O-rings - That's working :
Name:  IMG_4058 copie.jpg
2 questions :
I'm looking for a picture of the trunk closure system:
Attachment 1189538
I'm also looking for a picture of the system that maintained the battery in order to see where are located the 2 holes for hanging the rods.
Have a nice day,
Serge
PS70 is offline
