2000T new project - Page 10 - Alfa Romeo Bulletin Board & Forums
 4Likes
post #136 of 182 (permalink) Old 12-05-2016, 02:14 PM Thread Starter
Hi,
Steering box and relay are now as new.
CHS kit is just perfect.
Body work is going well too :
Name:  IMG_2743 copie.jpg
Name:  IMG_2741 copie.jpg
PS70 is offline
post #137 of 182 (permalink) Old 12-05-2016, 03:11 PM
Push hard and live
DPeterson3's Avatar
What part number CHS kit did you use? What is the casting number on your steering box? Did the kit come with a new pin for the sector gear?
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is online now
post #138 of 182 (permalink) Old 12-05-2016, 11:18 PM Thread Starter
Hello Don,
This is the configuration of the kit :
kit K2000-SL :
- 1 (one) Gear worm & shaft (shaft installed into the gear worm ).
- 1 (one) Roller-kit ( 1 roller, 1 pin for riveting, 2 oversize washers & the full complement of needle rollers)
- 1 (one) Lower bearing set ( 1 cup and 1 cage with tapered rollers )
- 1 (one) Upper bearing set ( 1 cup and 1 cage with tapered rollers )
- 3 (three) Oil seals
- 1 (one) Set of shims ( for adjusting the gear worm )
- 1 (one) Gasket ( for sector shaft cover )
- 2 (two) Housing bushings
I will check tonight the casting N.
PS70 is offline
post #139 of 182 (permalink) Old 12-06-2016, 11:01 AM Thread Starter
Don,
On the casting, there is a J9 :
Do you need something more (I will have to dismount the aluminium part to see more) ?
PS70 is offline
post #140 of 182 (permalink) Old 12-06-2016, 07:23 PM
Push hard and live
DPeterson3's Avatar
Steering box kit
Here are some pictures I took of the three boxes I'm working on. It should give you an idea to look for the longer number.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #141 of 182 (permalink) Old 12-06-2016, 11:19 PM Thread Starter
Ok,
v5001ar4
PS70 is offline
post #142 of 182 (permalink) Old 12-06-2016, 11:39 PM Thread Starter
Wink at Doug :
PS70 is offline
post #143 of 182 (permalink) Old 12-08-2016, 08:18 AM
Push hard and live
DPeterson3's Avatar
Serge,
Unless you revised all of the internals of the gear box to be the later style, the "EP" oil would be incorrect for an original-configuration 102 gearbox.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #144 of 182 (permalink) Old 12-08-2016, 08:52 AM Thread Starter
Don, this is what is written on the label :
"DO NOT USE OILS TYPE EP"
PS70 is offline
post #145 of 182 (permalink) Old 12-08-2016, 09:19 AM
Push hard and live
DPeterson3's Avatar
Ah. I was viewing it on my small Ipad, and when combined with my aging eyes, I cannot read things that small.
Exactly perfect, then.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #146 of 182 (permalink) Old 12-12-2016, 01:29 PM Thread Starter
Hello everybody,
In order to finalize the gear box I would like to reinstall the system that prevent to engage the reverse :
Name:  Levier de vitesses.jpg
I have found the 2 small ball, the small lever and its spring (102.02.13.607.03) :
Name:  IMG_2913 copie.jpg
Name:  IMG_2952 copie.jpg
But unfortunately, the finger 102.02.13.609.01 is still missing.
Does anyone could give me the size of this small finger so I could produce it ?
Serge
PS70 is offline
post #147 of 182 (permalink) Old 12-12-2016, 02:40 PM
Redmerlin's Avatar
reverse pin
Serge I have a box of gearbox bits , I'll have a look when I get home on Saturday rgds Ian
Redmerlin is offline
post #148 of 182 (permalink) Old 12-13-2016, 01:45 PM Thread Starter
OK Ian, thank you very much !
PS70 is offline
post #149 of 182 (permalink) Old 12-21-2016, 01:41 PM Thread Starter
Ian, did you find the time to check the reverse protection system of the gear box ?
Serge.
PS70 is offline
post #150 of 182 (permalink) Old 12-22-2016, 09:33 AM
Redmerlin's Avatar
Reverse pin
Serge - just had time today to look
Pin is 26.5mm long , 7.5mm -7.6mm diameter , tapped hole 17.5 mm from one end as photos
Note the one I have on my selector is bent , your one may have broken in half and exited through the gearbox, so needs to be made from high spec steel
As photos
rgds
Ian
