Hardtop - Page 6 - Alfa Romeo Bulletin Board & Forums
 3Likes
post #76 of 78 (permalink) Old 03-18-2017, 10:49 AM
IRONBLOCK's Avatar
Originally Posted by DPeterson3 View Post
How many different rear windows are there for 2000 and 2600 hard tops? I am guessing at least four...
Jay's suspicion that a single blank might be molded, and then cut down to suit the smaller windows strikes me as wishful thinking.
I've the rear window out of my top, which I believe to be a Mk1 version for the 2000. I don't mind making a mold, but just exactly how does one make a mold that suits a commercial fabricator?
Yes, I agree with the above: at least 3 or 4 variations & some wishful thinking; definitely tempered glass...I do believe that Larry's 'mold' is really a pattern made of fiberglass. The window manufacturer would probably have to make the actual mold from the pattern.
There is some degree of confusion over which hardtop window mold Larry actually has since his top required some degree of modification to fit his 2600. His top looks just like the one on my Two-liter (series 2) and his window had the exact same information etched into the glass (perhaps they all do?).
I'm not interested in heating and bending my perfectly good screen.
The process Ruedi described, involving heating and bending glass would be used to make a new formed window; not to make a mold or pattern. However, I do believe there is some relatively small amount of heat given off by the curing fiberglass that made Larry a little uncomfortable about the process. Still it would be great to have a mold for the Series 1 & Series 2 or 3? windows! It would be nice to think that Larry and you, should you decide to produce a mold or pattern, would be reimbursed for your mold making expenses. So far I have come close to breaking two very rare and difficult to find rear windows. It would be nice to know that a replacement window was at least a possibility.
Here are a couple of motivational clips on replacing the rear window:
One clip showing how a window glass is made.
Corvette hardtops are available from between 3,500 and $6,000 depending on the model. Rear windows run $200-300 each and complete rebuild kits cost about $1,200.
http://www.thehardtopshop.com/catego...-purchase.html
Mark
IRONBLOCK is offline
post #77 of 78 (permalink) Old 03-20-2017, 10:32 AM
twoliterlover's Avatar
Larry sent me his mold
Larry's mold measurements, once I got the mold from him, showed me that the 2600 series one rear hardtop window (while it might look almost identical) is at least two inches lower in height than my two liter hard top. That confirmed to me my suspicions. A very good friend of mine here in the Seattle area had a two liter hard top that he wanted to put on his 2600. It had no glass, but he was able somehow to get a brand new 2600 series one replacement glass. No, I do NOT know where he got the replacement glass, but it did NOT fit because the hole in his two liter series two hard top was taller than the 2600 series one glass. So I clearly understand and have seen the difference.
Secondly, despite DPETERSON3'S comment, Larry did indeed have a 2600 series one hardtop on his 2600. I know that because I one tried to furnish an original member of the Northwest Alfa Romeo Club, John Mendenhasll (RIP), one of what was at that time an extra two liter hard top of mine for his 2600. We could NOT make it fit because the rear deck of a 2600 bows up higher in the middle than the rear deck of a two liter. We could bolt down only one side. To grind down the two liter top to fit the higher 2600 rear deck would have required grinding away almost to the bottom of the glass itself.
I could see form Larry's photos of his car that his top was not that ground down, nor were there additions pieces building up on the side to provide more top to fit to the body there. Consequently, I say categorically that a two liter hard top cannot be made to fit a 2600. And if a 2600 top were to be fitted to a two liter there would have to be strange strange additions as well as grindings as to maie it, in my opinion, also impossible.
I well understand the desire for a real glass rear window. However, that would require a mold for EACH of the four types of hard tops because cutting glass once sized for one to fit another would be foolish and dicey at best, probably nigh impossible in fact.
My proposal is more realistic, and not all that revolting. I propose to make a slightly over-sized mold of my two liter rear hard top window the same way Larry made his (but maybe two inches larger on all sides), so plexiglass or some such aircraft window material could be properly bent that individual hard top owners of all four types could trim blanks make on it to fit any hard top. There is the hope that even the steeper 2x2 configuration hardtop of series two 2600 hardtop might be fitted in this manner. The two liter series two would be a snap, as well as both the series one of two liter and 2600 -- the amount of trimming just different.
But the idea of actually getting actual glass rear windows would require four different molds, in my opinion. As a final comment about glass versus plexiglas, I can only say that the reason so many hard tops are without glass rear windows is because they can be so easily broken when the top is taken off or being put on. All it takes is a drop or a twisting from being tightening down too violently without being carefully fitted. I believe the plexiglass would be (1) lighter, (2) sturdier, and (3) more realistic for Alfa lover who really would want to drive their cars sometimes with and sometimes without ardtop. Plexiglass can be shined up and marks removed by careful buffing and refinishing.
But I do confess I have been hesitant to have a mold made of my beautiful two liter hard top glass. I have promised several I will. And now that today is the first day of spring (I drove my spider over 100 miles through the beautiful Seattle area countryside yesterday with my Honeymom whose 80th birthday is TODAY). We are playing hookey today too. I am not going to do a lick of work in the office if I can only ignore the phones. Hooray for spring! May your Alfa run forever.
[B]JAY NUXOLL [/B][EMAIL="
"], seriously Alfa diseased and ancient OLD Two Liter Lover, put together Seattle area's Northwest Alfa Romeo Club in 1965, and still feebly tries to tend a teeny sacred flame to his serpent mistress in the [B]ALFA G'RAJ MAHAL[/B], a home garage temple with more Alfa cars and parts than he dare list because of the disapproval of his shamed and chagrined family. (425) 641-2600.
twoliterlover is offline
post #78 of 78 (permalink) Old 03-20-2017, 05:36 PM
Push hard and live
DPeterson3's Avatar
My memory must be failing.... I don't recall disputing this.
"Secondly, despite DPETERSON3'S comment, Larry did indeed have a 2600 series one hardtop on his 2600"
I'm not all that clear on what tops are what, but I'm open to learning.
By the way, might there be a 5th type? That would be for the very late 2000 whose rear seating area is constructed like a 2600, and so which might have a taller rear area for the hard top, but still have to fit the flatter rear deck area of the 2000? I dunno about this. Just guessing.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
